주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Visual Land Prestige Pro 7D Reset Button Replacement
필요한 것
    1. Visual Land Prestige Pro 7D Reset Button Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
      • Unscrew the two 4.0mm Phillips head screws found near the ports at the bottom of the device using a PH #00 screwdriver.
      댓글 쓰기
    2. Visual Land Prestige Pro 7D Reset Button Replacement: 2 단계, 이미지 1개 중 1개
      • Be careful when taking the back panel off. The speaker is connected to both the front and back panels, and may get pulled out if you are not gentle when lifting the back panel away.
      • Slide the plastic prying tool in between the front and back panel and pry them apart on all 4 sides.
      • It may be easiest to start on one of the sides, and work your way around the device. The bottom, with the ports, is the most difficult side and can be saved for last.
      • There are small latches that make this difficult. Moderate force may be required to separate the two panels.
      댓글 쓰기
    1. Visual Land Prestige Pro 7D Reset Button Replacement, Reset Button: 3 단계, 이미지 2개 중 1개 Visual Land Prestige Pro 7D Reset Button Replacement, Reset Button: 3 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Use the tweezers to lift the grey connector, located next to the reset button, up from the beige housing. It should rotate up, and allow you to slide the ribbon out from under the connector.
      • Although not necessary for replacing the reset button, it is highly recommended to disconnect the ribbon. This ensures it will not get damaged during desoldering.
      댓글 쓰기
    2. Visual Land Prestige Pro 7D Reset Button Replacement: 4 단계, 이미지 3개 중 1개 Visual Land Prestige Pro 7D Reset Button Replacement: 4 단계, 이미지 3개 중 2개 Visual Land Prestige Pro 7D Reset Button Replacement: 4 단계, 이미지 3개 중 3개
      • Soldering guns are hot and can easily damage the device.
      • Desolder the four side dots holding the reset button in place.
      • If this is your first time desoldering, here is a helpful guide to show you 연결부 납땜 및 납제거 방법.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Jennifer Laybourn
회원 가입일: 10/14/14
353 평판
안내서 2개를 작성함
Cal Poly, Team 10-41, Amido Fall 2014 Cal Poly, Team 10-41, Amido Fall 2014 회원
CPSU-AMIDO-F14S10G41
4 회원들
안내서 42개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 2
지난 30일: 25
전체 시간: 3,935
