주요 콘텐츠로 건너뛰기
Vornado 133 Compact Air Circulator Fuse Replacement
필요한 것
  1. Vornado 133 Compact Air Circulator Fuse Replacement, Fuse: 1 단계, 이미지 1/1
    • Ensure the unit is powered off and remove the plug from the outlet.
  2. Vornado 133 Compact Air Circulator Fuse Replacement: 2 단계, 이미지 1/3 Vornado 133 Compact Air Circulator Fuse Replacement: 2 단계, 이미지 2/3 Vornado 133 Compact Air Circulator Fuse Replacement: 2 단계, 이미지 3/3
    • Slide open the fuse access cover on the top of the plug by moving it towards the end of the plug.
  3. Vornado 133 Compact Air Circulator Fuse Replacement: 3 단계, 이미지 1/3 Vornado 133 Compact Air Circulator Fuse Replacement: 3 단계, 이미지 2/3 Vornado 133 Compact Air Circulator Fuse Replacement: 3 단계, 이미지 3/3
    • Use a pair of tweezers or a small plastic spudger to remove the fuse from the fuse casing. Remove the end nearer to the fan body first, then the end nearer to the plug end.
    • The replacement fuse must be 2.5 amp, 125 volt.
    • Do not push against the glass center of the fuse, only the metal end pieces.
결론
Follow these instructions in reverse order to install the new fuse and close the access panel.
다른 10명이 해당 안내서를 완성하였습니다.
Erin Klein
회원 가입일: 07/06/17
468 평판
안내서 3개 작성하였습니다
UW Tacoma, Team S1-G2, Liner Summer 2017 UW Tacoma, Team S1-G2, Liner Summer 2017 회원
UWT-LINER-SU17S1G2
4 회원들
안내서 4개 작성하였습니다
댓글 10개
Great post! This saved me $60 from buying a new fan! Thank you!
jamiekim808 - 답글
Thanks for posting. Ordered a pack of 50 fuses from amazon for $7.97
TLCIMMORTAL - 답글
Fast-acting or slow-acting?
James Olsen - 답글
Wow, I was going to throw this fan in trash and seeing your instructions I saved it
Anupam B - 답글
thanks buddy, just bought the fan ,son stuck a pencil in it , Quick fix
BOBBY C - 답글
댓글 쓰기
조회 통계:
24 시간 전: 10
7일 전: 51
30일 전: 370
전체 시간: 30,816
