주요 콘텐츠로 건너뛰기
Vornado Duo Fuse Replacement
Tyler Pettenger
Tyler Pettenger3 다른 기여자
최종 수정일 March 7, 2024
2 분
쉬움
In this replacement guide, step-by-step instructions show how to approach replacing the fuse in the power cord plug of the Vornado Duo.
필요한 것
iFixit은 귀하가 이 링크를 통해 구매할 때 커미션을 받습니다.
  1. Vornado Duo Fuse Replacement, Fuse: 1 단계, 이미지 1개 중 1개
    • Grasp plug and remove from the receptacle or other outlet device.
    • Do not unplug by pulling on cord.
  2. Vornado Duo Fuse Replacement: 2 단계, 이미지 1개 중 1개
    • Open fuse cover by sliding access cover on top of attachment plug.
  3. Vornado Duo Fuse Replacement: 3 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    • Remove fuse carefully by gently prying out the ends of the fuse from the receptacle again using the driver with the 2mm flathead.
    • Risk of fire. Replace fuse only with 2.5 Amp, 125 Volt fuse.
  4. Vornado Duo Fuse Replacement: 4 단계, 이미지 1개 중 1개
    • Install replacement fuse by first placing the end of the fuse into the fuse receptacle which is opposite of the blades of the plug, then carefully push in the other end. (Only push against the metal end of the fuse, not the glass center portion)
  5. Vornado Duo Fuse Replacement: 5 단계, 이미지 1개 중 1개
    • Close the fuse access cover by sliding the cover back into the plug until it is completely closed, latches and is flush with the face of the plug. (Risk of fire. Do not replace attachment plug. Contains a safety device that should not be removed.)
결승점
다른 6명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Tyler Pettenger
회원 가입일: 09/28/17
563 평판
안내서 3개를 작성함
USF Tampa, Team S1-G1, Nance Fall 2017 USF Tampa, Team S1-G1, Nance Fall 2017 회원
USFT-NANCE-F17S1G1
3 회원들
안내서 4개를 작성함
댓글 6개
It’s still not working for me - I’ve cleaned the whole fan, put it back together and changed the fuse. Any tips? Thank you.
Whitney Sturner - 답글
Did you ever get an answer? I'm having the same problem
bysgamer617 - 답글
Probably a damaged circuit board capacitor, search out a micro-electronic repair shop. Or, authorized dealer. Often you can find a repair that understands multiple board systems and can easily test and repair your fan. An example, Apple technologies.
GW Roberts (GW) - 답글
Please remember, if you purchase the fan from any source other than an authorized dealership, who has invested money and training, the manufacturer has NO responsibility to that unauthorized purchase.
Is there “a tell” that the problem is the motor or circuit board before searching for fuses? For the 1st micro second it moves an inch like it’s getting power.
Djlaine17 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 17
지난 30일: 44
전체 시간: 15,837
