주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Vtech Kidizoom Smart Watch DX Buttons Replacement
필요한 것
    1. Vtech Kidizoom Smart Watch DX Buttons Replacement, Master Switch: 1 단계, 이미지 1개 중 1개
      • Make sure the master switch is "OFF" before disassembly, to avoid an electric shock.
      • Flip the watch over with the back facing up.
      댓글 쓰기
    2. Vtech Kidizoom Smart Watch DX Buttons Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the four 6.0 mm screws on the back plate with the Phillips #00 screwdriver.
      댓글 쓰기
    3. Vtech Kidizoom Smart Watch DX Buttons Replacement: 3 단계, 이미지 1개 중 1개
      • Gently pull the back plate from the watch casing.
      댓글 쓰기
    4. Vtech Kidizoom Smart Watch DX Buttons Replacement: 4 단계, 이미지 2개 중 1개 Vtech Kidizoom Smart Watch DX Buttons Replacement: 4 단계, 이미지 2개 중 2개
      • Lift the master switch from the circuit board.
      댓글 쓰기
    1. Vtech Kidizoom Smart Watch DX Buttons Replacement, Circuit Board: 5 단계, 이미지 2개 중 1개 Vtech Kidizoom Smart Watch DX Buttons Replacement, Circuit Board: 5 단계, 이미지 2개 중 2개
      • The speaker wires are fragile. They may break if excessive force is used to remove the circuit board.
      • Removal of the circuit board requires soldering.
      • Gently push on the display from the front, near the camera. The circuit board and display will pop out through the back.
      댓글 쓰기
    2. Vtech Kidizoom Smart Watch DX Buttons Replacement: 6 단계, 이미지 1개 중 1개
      • Lift the circuit board carefully from the casing, without breaking or detaching the speaker wires at the bottom of the circuit board.
      댓글 쓰기
    3. Vtech Kidizoom Smart Watch DX Buttons Replacement: 7 단계, 이미지 1개 중 1개
      • Note which wire is connected to which lead before continuing. There are no markers on the circuit board to indicate where each wire belongs.
      • De-solder the black speaker wire from the circuit board.
      댓글 쓰기
    4. Vtech Kidizoom Smart Watch DX Buttons Replacement: 8 단계, 이미지 1개 중 1개
      • De-solder the red speaker wire, as in the previous step.
      댓글 쓰기
    5. Vtech Kidizoom Smart Watch DX Buttons Replacement: 9 단계, 이미지 1개 중 1개
      • Wait for the solder to cool down and solidify, then remove the circuit board from the casing.
      댓글 쓰기
    1. Vtech Kidizoom Smart Watch DX Buttons Replacement, Buttons: 10 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Use the the tweezers to pull off the blue rubber cover behind the button.
      • The blue cover is adhesive, so you can stick it back onto the back of the buttons after replacement.
      댓글 쓰기
    2. Vtech Kidizoom Smart Watch DX Buttons Replacement: 11 단계, 이미지 1개 중 1개
      • Use tweezers to separate the backside tab from the front side of the button.
      댓글 쓰기
    3. Vtech Kidizoom Smart Watch DX Buttons Replacement: 12 단계, 이미지 1개 중 1개
      • Push the other half of the button out of the casing.
      • Repeat steps 11 and 12 for all buttons.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Mohammed Alyaarubi
회원 가입일: 01/20/16
365 평판
안내서 1개를 작성함
USF Tampa, Team 10-6, Remmell Spring 2016 USF Tampa, Team 10-6, Remmell Spring 2016 회원
USFT-REMMELL-S16S10G6
4 회원들
안내서 48개를 작성함
1가이드 댓글
Where can you buy the replacement cover?
Katrina Nullatamby - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 18
지난 30일: 64
전체 시간: 6,577
