주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Wacom Intuos Pro Battery Replacement
필요한 것
    1. Wacom Intuos Pro Battery Replacement, Battery: 1 단계, 이미지 3개 중 1개 Wacom Intuos Pro Battery Replacement, Battery: 1 단계, 이미지 3개 중 2개 Wacom Intuos Pro Battery Replacement, Battery: 1 단계, 이미지 3개 중 3개
      • Orient the device so the bottom casing is facing upwards.
      • Use your fingers to gently pull on the rubber covers on the bottom of the device to remove them.
      댓글 쓰기
    2. Wacom Intuos Pro Battery Replacement: 2 단계, 이미지 3개 중 1개 Wacom Intuos Pro Battery Replacement: 2 단계, 이미지 3개 중 2개 Wacom Intuos Pro Battery Replacement: 2 단계, 이미지 3개 중 3개
      • Remove the four 4mm screws from underneath the rubber feet using a Phillips #00 screwdriver.
      • The screws are located 40mm in from the edge, so it not necessary to completely remove the rubber if you prefer not to.
      댓글 쓰기
    3. Wacom Intuos Pro Battery Replacement: 3 단계, 이미지 2개 중 1개 Wacom Intuos Pro Battery Replacement: 3 단계, 이미지 2개 중 2개
      • Insert the iFixit Opening Tool between the front and back cover of the device in order to snap and separate the type locks from around the edges.
      • Use the iFixit Opening Tool all the way around the edges until all the snaps have been released.
      • While going around the edges, make sure you have a tight grip to keep the device from sliding.
      댓글 쓰기
    4. Wacom Intuos Pro Battery Replacement: 4 단계, 이미지 2개 중 1개 Wacom Intuos Pro Battery Replacement: 4 단계, 이미지 2개 중 2개
      • Remove the case backing from the rear of the device with your hands so the internal components are exposed.
      댓글 쓰기
    5. Wacom Intuos Pro Battery Replacement: 5 단계, 이미지 2개 중 1개 Wacom Intuos Pro Battery Replacement: 5 단계, 이미지 2개 중 2개
      • If not already done, desolder the three colored cables that connect the battery to the motherboard.
      • After desoldering the battery, carefully remove it.
      • Be careful when handling the soldering iron given it's high operating temperature and the possibility for it to damage other components.
      • For help soldering, check out our How to Solder and Desolder Connections guide.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
7가이드 댓글
thank you so much. I plan to buy this wacom, however I had the doubt if better the old version that has extractable battery, but with this post, I can go for the new one
Sebastian Ramirez - 답글 공유
Do you know where can I find the battery replacement?
Valerio _ - 답글 공유
Has anyone got a lint to the replacement battery?
Luca Di Meo - 답글 공유
PTH-660 works fine without the battery, just remove it and use it with USB cable
Luca Di Meo - 답글 공유
Where can I find a replacement battery for this model?
Denise Hanly - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 34
지난 30일: 176
전체 시간: 11,824
