주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Wacom Intuos Pro Touch Pad Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
    1. Wacom Intuos Pro Touch Pad Replacement, Battery: 1 단계, 이미지 3개 중 1개 Wacom Intuos Pro Touch Pad Replacement, Battery: 1 단계, 이미지 3개 중 2개 Wacom Intuos Pro Touch Pad Replacement, Battery: 1 단계, 이미지 3개 중 3개
      • Orient the device so the bottom casing is facing upwards.
      • Use your fingers to gently pull on the rubber covers on the bottom of the device to remove them.
      댓글 쓰기
    2. Wacom Intuos Pro Touch Pad Replacement: 2 단계, 이미지 3개 중 1개 Wacom Intuos Pro Touch Pad Replacement: 2 단계, 이미지 3개 중 2개 Wacom Intuos Pro Touch Pad Replacement: 2 단계, 이미지 3개 중 3개
      • Remove the four 4mm screws from underneath the rubber feet using a Phillips #00 screwdriver.
      • The screws are located 40mm in from the edge, so it not necessary to completely remove the rubber if you prefer not to.
      댓글 쓰기
    3. Wacom Intuos Pro Touch Pad Replacement: 3 단계, 이미지 2개 중 1개 Wacom Intuos Pro Touch Pad Replacement: 3 단계, 이미지 2개 중 2개
      • Insert the iFixit Opening Tool between the front and back cover of the device in order to snap and separate the type locks from around the edges.
      • Use the iFixit Opening Tool all the way around the edges until all the snaps have been released.
      • While going around the edges, make sure you have a tight grip to keep the device from sliding.
      댓글 쓰기
    4. Wacom Intuos Pro Touch Pad Replacement: 4 단계, 이미지 2개 중 1개 Wacom Intuos Pro Touch Pad Replacement: 4 단계, 이미지 2개 중 2개
      • Remove the case backing from the rear of the device with your hands so the internal components are exposed.
      댓글 쓰기
    5. Wacom Intuos Pro Touch Pad Replacement: 5 단계, 이미지 2개 중 1개 Wacom Intuos Pro Touch Pad Replacement: 5 단계, 이미지 2개 중 2개
      • If not already done, desolder the three colored cables that connect the battery to the motherboard.
      • After desoldering the battery, carefully remove it.
      • Be careful when handling the soldering iron given it's high operating temperature and the possibility for it to damage other components.
      • For help soldering, check out our How to Solder and Desolder Connections guide.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
6다른 기여자 명과 함께
Luis Alva
회원 가입일: 01/15/20
253 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 31
전체 시간: 1,078
