주요 콘텐츠로 건너뛰기
Wahl Chrome Pro Power Switch Replacement
Holly Dunn
Holly Dunn4 다른 기여자
최종 수정일 July 15, 2024
10 분
쉬움
액션 샷
The power switch connects the device motor to the power cord. If the power switch becomes broken or worn, the device may not function properly.
필요한 것
도구
더보기...
iFixit은 귀하가 이 링크를 통해 구매할 때 커미션을 받습니다.
  1. Wahl Chrome Pro Power Switch Replacement, Case: 1 단계, 이미지 1개 중 1개
    • Remove the two 5.0 mm JIS #1 screws to loosen the cutting blades.
    • Make sure your device is not connected to power before you begin.
  2. Wahl Chrome Pro Power Switch Replacement: 2 단계, 이미지 1개 중 1개
    • Lift the bottom blade straight up from the device body to remove it.
  3. Wahl Chrome Pro Power Switch Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the three 9.0 mm JIS #1 screws attaching the base of the blade assembly to the body.
  4. Wahl Chrome Pro Power Switch Replacement: 4 단계, 이미지 1개 중 1개
    • Lift the base of blade assembly straight up off of the body.
  5. Wahl Chrome Pro Power Switch Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the two 12.0 mm JIS #1 screws on the back of the device body.
  6. Wahl Chrome Pro Power Switch Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the 13.0 mm Phillips #2 screw on the side of the device body.
    • This screw is located on the opposite side of the body from the switch.
  7. Wahl Chrome Pro Power Switch Replacement: 7 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Remove the spring on the side of the body using tweezers.
  8. Wahl Chrome Pro Power Switch Replacement: 8 단계, 이미지 1개 중 1개
    • Pry the body case off of the device using a spudger.
  9. Wahl Chrome Pro Power Switch Replacement, Power Switch: 9 단계, 이미지 1개 중 1개
    • Remove one 7.5 mm JIS #1 screw connecting the power cord to the switch base.
  10. Wahl Chrome Pro Power Switch Replacement: 10 단계, 이미지 1개 중 1개
    • Remove one 7.5 mm JIS #1 screw connecting the wire to the switch base.
  11. Wahl Chrome Pro Power Switch Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the switch from device by lifting straight up from the device body.
결론
작성자
4다른 기여자 명과 함께
Holly Dunn
회원 가입일: 11/09/17
104 평판
안내서 1개를 작성함
IUPUI, Team S7-G3, Baechle Fall 2017 IUPUI, Team S7-G3, Baechle Fall 2017 회원
IUPUI-BAECHLE-F17S7G3
3 회원들
안내서 8개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 6
전체 시간: 573
