주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Whirlpool Refrigerator Control Board Replacement
필요한 것
    1. Whirlpool Refrigerator Control Board Replacement, Safety precautions: 1 단계, 이미지 1개 중 1개
      • Before you begin your repair, perform the following:
      • Turn off your main water supply
      • Unplug your device
      댓글 쓰기
    1. Whirlpool Refrigerator Control Board Replacement, Unfasten the dispenser panels: 2 단계, 이미지 2개 중 1개 Whirlpool Refrigerator Control Board Replacement, Unfasten the dispenser panels: 2 단계, 이미지 2개 중 2개
      • The dispenser panel screws are located under the dispenser as if you're looking up into the dispenser tube (where the ice cubes and water come out).
      • Remove the screw(s) securing the two dispenser panels.
      댓글 쓰기
    2. Whirlpool Refrigerator Control Board Replacement, Remove the dispenser panels: 3 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Control Board Replacement, Remove the dispenser panels: 3 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Control Board Replacement, Remove the dispenser panels: 3 단계, 이미지 3개 중 3개
      • Pull the dispenser panels straight down to separate them from the chassis.
      • Remove the dispenser panels.
      댓글 쓰기
    3. Whirlpool Refrigerator Control Board Replacement, Unfasten the control board: 4 단계, 이미지 1개 중 1개
      • Remove the screw(s) securing the control board.
      댓글 쓰기
    4. Whirlpool Refrigerator Control Board Replacement: 5 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Control Board Replacement: 5 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Control Board Replacement: 5 단계, 이미지 3개 중 3개
      • Tilt the bottom of the control board away from the chassis to release its clips.
      • Pull straight down to separate the control board enough to access its connectors.
      댓글 쓰기
    5. Whirlpool Refrigerator Control Board Replacement, Disconnect the control board: 6 단계, 이미지 3개 중 1개 Whirlpool Refrigerator Control Board Replacement, Disconnect the control board: 6 단계, 이미지 3개 중 2개 Whirlpool Refrigerator Control Board Replacement, Disconnect the control board: 6 단계, 이미지 3개 중 3개
      • Disconnect the connectors attached to the control board.
      댓글 쓰기
    6. Whirlpool Refrigerator Control Board Replacement, Remove the control board: 7 단계, 이미지 1개 중 1개
      • Remove the control board.
      댓글 쓰기
결론
Repair didn’t go as planned? Ask our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
nicO
회원 가입일: 04/14/15
15,990 평판
안내서 89개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 41
지난 30일: 145
전체 시간: 6,265
