주요 콘텐츠로 건너뛰기
Wii U GamePad Battery Replacement
Valentina Cerruty
Valentina Cerruty6 다른 기여자
최종 수정일 March 20, 2025
2 - 3 분
매우 쉬움
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
In order to remove the battery, you will need the tool PH0. (small scredriver) This guide will help you to remove the battery and be able to remove the Nintendo's case.
필요한 것
부품
도구
더보기...
  1. Wii U GamePad Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Place Gamepad face down and remove the two 4.7 mm screws with a Phillips size #00 screwdriver.
  2. Wii U GamePad Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Lift and remove the battery plate.
  3. Wii U GamePad Battery Replacement: 3 단계, 이미지 3개 중 1개 Wii U GamePad Battery Replacement: 3 단계, 이미지 3개 중 2개 Wii U GamePad Battery Replacement: 3 단계, 이미지 3개 중 3개
    • With your finger, press down and pull back on the battery connector plug.
    • Remove the battery from the battery case.
결론
다른 26명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Valentina Cerruty
회원 가입일: 02/10/16
3,455 평판
안내서 7개를 작성함
USF Tampa, Team 1-6, Sullivan Spring 2016 USF Tampa, Team 1-6, Sullivan Spring 2016 회원
USFT-SULLIVAN-S16S1G6
4 회원들
안내서 40개를 작성함
댓글 3개
I'm trying to put in the new battery, but the connector won't snap in even with larger amounts of force. The original battery, on the other hand, snaps right in.
ToastyGhost - 답글
I have the same issue. The connector on the new battery does not snap in. Does anyone know how to fix this issue and ger the connector to snap into place?
Encom - 답글
It takes a significant amount of pressure (in my opinion) to get the ifixit wii u gamepad battery to snap into place. When I successfully installed this battery, I laid the wii u gamepad screen down with the top of the gamepad facing me. Then I took the flat end of my ifixit spudger, and while pressing down on the battery connector at a 45 degree angle, I pushed the battery connector into the port. You'll be able to tell when the battery is connected all the way. However, this battery does NOT make a snap or click sound to let you know it's connected all the way.
Link to the spudger I used: Spudger
RakmanII -
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 110
전체 시간: 14,685
