주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Windows 10 Migration to Linux - Supplement
      • **Disclaimer**
      • Installing Linux will permanently erase your PC and any data. Make sure you have the data stored elsewhere (OneDrive, GoogleDrive, external USB, etc).
      • If you think you might want to go back to Windows 10, create a recovery USB drive before starting the Linux install process
      댓글 쓰기
    1. 댓글 쓰기
    2. Windows 10 Migration to Linux - Supplement: 3 단계, 이미지 1개 중 1개
      • General Linux Tips and Tricks
      • Linux Updates
      • Despite what the Repair Cafe user guide says, updates seem to come through every few days. Check the icon on the toolbar. I would suggest installing updates at least every week or every time you use the PC (if less frequent than weekly). Look out for black/white shield in the toolbar with a red dot on it.
      • You can also set to update automatically. Open Update Manager and go to Edit->Preferences. Set the options as per the picture
      댓글 쓰기
    3. Windows 10 Migration to Linux - Supplement: 4 단계, 이미지 1개 중 1개
      • Microsoft Office 365
      • Either Google Chrome or Microsoft Edge will work for accessing Office 365. Edge has slightly better integration, so I would recommend this. First of all install Microsoft Edge to access OneDrive files and the Microsoft apps (Word, Excel, PowerPoint, etc).
      • The install isn’t listed in the Software Manager, but you can find it here. Install the Linux (.deb) version.
      • Once Edge is installed, log into Edge using your Microsoft Office 365 credentials.
      • Open a new tab and from the top left click the 9 dots, you can now access your Microsoft apps and OneDrive.
      • For Teams, there is a native app on Linux, just search for Teams from the Start menu. Or go to the Web version of Teams and when prompted to launch/install the app, select yes.
      • There are some serious limitations of the web versions of the apps. Formatting in particular is not accurately retained. There are some features of the desktop versions of the office apps that are not available in the web version. I would recommend using the web apps for a few weeks prior to committing to moving to Linux.
      • Works best when files to edit are kept on OneDrive. More advanced editing, formatting and controls are not available in the web versions. An Internet connection is necessary at all times.
      댓글 쓰기
      • Google Drive/Docs/Etc
      • If you use the Google equivalent of Microsoft 365, then you’ll already be familiar in accessing through a browser. Google Chrome or Microsoft Edge work well. But Chrome is likely to be better integrated <needs updating if anyone is more familiar with the Google office suite?>
      댓글 쓰기
      • Linux LibreOffice
      • Linux Mint installs the LibreOffice apps by default. They provide good functionality and should allow Office 365 or Google Apps files to be opened and edited. Like most instances where a file is opened with a different app to the one it was created with, there are likely to be some loss of features and formatting that needs correcting.
      댓글 쓰기
      • Other Apps
      • Video Conferencing
      • Microsoft Teams has a native Linux app. Open Teams in the browser and it should prompt to use/install the Teams app. Alternatively just use Teams in the browser.
      • Zoom also has a native Linux app. It isn’t available in Software Manager, but you can download from this link. Go to “Meet”=>"Download App”. Select the Mint, 64 bit version
      • WhatsApp
      • You can use the web version from this link. Follow the instructions to link to your phone
      댓글 쓰기
결론
If you wish to revert to Windows 10, you must use the USB recovery drive created before commencing the Linux install
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Simon G
회원 가입일: 09/27/24
277 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 34
전체 시간: 138
