주요 콘텐츠로 건너뛰기
Windsor Willow Bottom Bracket Replacement
Walker Cobb
Walker Cobb3 다른 기여자
최종 수정일 April 20, 2017
10 분
조정
추천 가이드
This is a guide to removing and replacing the bottom bracket on the Windsor Willow. The bottom bracket is a self-contained bearing surface on which the crank arms and drive gears rotate. Note that the rear wheel is missing in the photos, but does not necessarily need to be removed for this guide.
  1. Windsor Willow Bottom Bracket Replacement, Chain: 1 단계, 이미지 1개 중 1개
    • The chain connects the crank arm to the gear cluster on the back wheel.
  2. Windsor Willow Bottom Bracket Replacement: 2 단계, 이미지 1개 중 1개
    • On the chain, locate the master link. It is a lighter gray than the other links of the chain. This is how you can break the chain for easier removal.
  3. Windsor Willow Bottom Bracket Replacement: 3 단계, 이미지 2개 중 1개 Windsor Willow Bottom Bracket Replacement: 3 단계, 이미지 2개 중 2개
    • To separate the Master Link, hold the left side of the link in your left hand and the link to the right in your right hand. Push the two links together to enable the release. Pull the links apart, one hand moving towards yourself and the other away from you. This will separate the links of the chain.
  4. Windsor Willow Bottom Bracket Replacement: 4 단계, 이미지 1개 중 1개
    • Once you have separated the links of the chain, pull down on the right side of the chain as shown. Pull until the chain has been fully removed from the gears. Place the chain on a paper towel or cloth to prevent getting grease anywhere.
  5. Windsor Willow Bottom Bracket Replacement, Crankshaft: 5 단계, 이미지 1개 중 1개
    • The crank arms can be located between the front and rear tire, directly below the seat.
  6. Windsor Willow Bottom Bracket Replacement: 6 단계, 이미지 1개 중 1개
    • To remove the crank arm, place a proper fitting Allen wrench into the slot at the center of the crank arm as shown. Turn the wrench counterclockwise to loosen the bolt that keeps the crank arm on the bike until it spins easily. Hold the other crank arm in place to ensure that the bolt loosens instead of spinning the crank arm.
  7. Windsor Willow Bottom Bracket Replacement: 7 단계, 이미지 1개 중 1개
    • Once the bolt spins easily, keep the Allen wrench in the bolt slot and turn the crank arms to speed up the removal process.
  8. Windsor Willow Bottom Bracket Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the bolt from the crank arm. The crank arm will remain in place. Do not try to pull off the crank arm, as a special tool is required for this task.
  9. Windsor Willow Bottom Bracket Replacement: 9 단계, 이미지 3개 중 1개 Windsor Willow Bottom Bracket Replacement: 9 단계, 이미지 3개 중 2개 Windsor Willow Bottom Bracket Replacement: 9 단계, 이미지 3개 중 3개
    • Repeat steps 2-4 on the other crank arm. Remember, do not try to pull off the crank arms.
  10. Windsor Willow Bottom Bracket Replacement: 10 단계, 이미지 1개 중 1개
    • Obtain a crank puller tool. This tool has two parts, a movable threaded insert and the push bolt. Screw the crank puller into the hole left by the bolt.
    • Be sure to be gentle and thread the first few turns by hand as to not accidentally cross thread your crankarms.
  11. Windsor Willow Bottom Bracket Replacement: 11 단계, 이미지 3개 중 1개 Windsor Willow Bottom Bracket Replacement: 11 단계, 이미지 3개 중 2개 Windsor Willow Bottom Bracket Replacement: 11 단계, 이미지 3개 중 3개
    • Once the movable piece is tightened firmly inside the hole, turn the tool clockwise. This will pull the crank arm away from the bike and remove it completely.
  12. Windsor Willow Bottom Bracket Replacement: 12 단계, 이미지 3개 중 1개 Windsor Willow Bottom Bracket Replacement: 12 단계, 이미지 3개 중 2개 Windsor Willow Bottom Bracket Replacement: 12 단계, 이미지 3개 중 3개
    • Repeat steps 6-7 with the remaining crank arm. Both arms have been successfully removed.
  13. Windsor Willow Bottom Bracket Replacement, Bottom Bracket: 13 단계, 이미지 1개 중 1개
    • The Bottom Bracket is located at the bottom of the frame, directly underneath the saddle.
  14. Windsor Willow Bottom Bracket Replacement: 14 단계, 이미지 2개 중 1개 Windsor Willow Bottom Bracket Replacement: 14 단계, 이미지 2개 중 2개
    • On the non-drive side, insert the bottom bracket removal tool into the splines on the inside of the bottom bracket mounting ring.
    • Fit the crescent wrench onto the bottom bracket removal tool.
    • Use the crescent wrench to turn the mounting ring counterclockwise until it is loose enough to turn by hand.
  15. Windsor Willow Bottom Bracket Replacement: 15 단계, 이미지 2개 중 1개 Windsor Willow Bottom Bracket Replacement: 15 단계, 이미지 2개 중 2개
    • Turn the bottom bracket removal tool counterclockwise by hand until the mounting ring is free of the bicycle frame
  16. Windsor Willow Bottom Bracket Replacement: 16 단계, 이미지 3개 중 1개 Windsor Willow Bottom Bracket Replacement: 16 단계, 이미지 3개 중 2개 Windsor Willow Bottom Bracket Replacement: 16 단계, 이미지 3개 중 3개
    • Fit the bottom bracket removal tool into the splines on the drive-side of the bottom bracket.
    • Use the crescent wrench to turn the bottom bracket removal tool clockwise until the bottom bracket is loose enough to turn by hand.
  17. Windsor Willow Bottom Bracket Replacement: 17 단계, 이미지 2개 중 1개 Windsor Willow Bottom Bracket Replacement: 17 단계, 이미지 2개 중 2개
    • Turn the bottom bracket removal tool clockwise by hand until its threads are no longer in contact with those of the frame.
    • Pull the bottom bracket out of the bike frame.
결론
To reassemble your device, follow these instructions in reverse order, keeping in mind that the drive-side threads are reverse threads, meaning counterclockwise turning tightens the piece and clockwise turning loosens the piece.
작성자
3다른 기여자 명과 함께
Walker Cobb
회원 가입일: 01/24/17
101 평판
안내서 1개를 작성함
Cal Poly, Team 10-6, Banghart Winter 2017 Cal Poly, Team 10-6, Banghart Winter 2017 회원
CPSU-BANGHART-W17S10G6
5 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 439
