주요 콘텐츠로 건너뛰기
Windsor Willow Brake Pad Replacement
Ethan
Ethan2 다른 기여자
최종 수정일 April 13, 2017
예상시간 없음
쉬움
This process requires just one tool and the removal of the tire.
필요한 것
iFixit은 귀하가 이 링크를 통해 구매할 때 커미션을 받습니다.
  1. Windsor Willow Brake Pad Replacement, Chain: 1 단계, 이미지 1개 중 1개
    • The chain connects the crank arm to the gear cluster on the back wheel.
  2. Windsor Willow Brake Pad Replacement: 2 단계, 이미지 1개 중 1개
    • On the chain, locate the master link. It is a lighter gray than the other links of the chain. This is how you can break the chain for easier removal.
  3. Windsor Willow Brake Pad Replacement: 3 단계, 이미지 2개 중 1개 Windsor Willow Brake Pad Replacement: 3 단계, 이미지 2개 중 2개
    • To separate the Master Link, hold the left side of the link in your left hand and the link to the right in your right hand. Push the two links together to enable the release. Pull the links apart, one hand moving towards yourself and the other away from you. This will separate the links of the chain.
  4. Windsor Willow Brake Pad Replacement: 4 단계, 이미지 1개 중 1개
    • Once you have separated the links of the chain, pull down on the right side of the chain as shown. Pull until the chain has been fully removed from the gears. Place the chain on a paper towel or cloth to prevent getting grease anywhere.
  5. Windsor Willow Brake Pad Replacement, Rear Wheel: 5 단계, 이미지 1개 중 1개
    • Hold the bicycle so that the bicycle wheels rests in the air and able to stand on its own.
  6. Windsor Willow Brake Pad Replacement: 6 단계, 이미지 2개 중 1개 Windsor Willow Brake Pad Replacement: 6 단계, 이미지 2개 중 2개
    • Open the sidepull brakes by fully rotating the title lever on the brake upwards.
  7. Windsor Willow Brake Pad Replacement: 7 단계, 이미지 2개 중 1개 Windsor Willow Brake Pad Replacement: 7 단계, 이미지 2개 중 2개
    • To loosen the wheel, simply pull out the lever, away from the frame and loosen up.
  8. Windsor Willow Brake Pad Replacement: 8 단계, 이미지 1개 중 1개
    • When the quick release is opened, the wheel is ready to remove.
  9. Windsor Willow Brake Pad Replacement, Locate Hex Bolt: 9 단계, 이미지 2개 중 1개 Windsor Willow Brake Pad Replacement, Locate Hex Bolt: 9 단계, 이미지 2개 중 2개
    • The hex bolt is what fastens each brake pad to the caliper. We will need to remove these to replace each pad.
  10. Windsor Willow Brake Pad Replacement, Unscrew the Hex Bolt: 10 단계, 이미지 3개 중 1개 Windsor Willow Brake Pad Replacement, Unscrew the Hex Bolt: 10 단계, 이미지 3개 중 2개 Windsor Willow Brake Pad Replacement, Unscrew the Hex Bolt: 10 단계, 이미지 3개 중 3개
    • Using an open end 10mm wrench, unscrew the hex nut from the caliper. After the nut is loosened you can use your fingers to finish the job. Repeat the same process on the other side for removal of the second brake pad.
결론
작성자
2다른 기여자 명과 함께
Ethan
회원 가입일: 01/26/17
201 평판
안내서 2개를 작성함
Cal Poly, Team 10-6, Banghart Winter 2017 Cal Poly, Team 10-6, Banghart Winter 2017 회원
CPSU-BANGHART-W17S10G6
5 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 95
