주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xbox 360 Preventative Maintenance
필요한 것
    1. Xbox 360 Preventative Maintenance, Replace the DVD drive belt: 1 단계, 이미지 1개 중 1개
      • The DVD drive belt, which allows the DVD drive to open when the motor spins, stretches and becomes misshapen over time, eventually stopping the drive from opening.
      • With how old the Xbox 360 is now, it may not be long before your drive belt stretches and becomes misshapen.
      • Follow this guide to replace it.
      댓글 쓰기
    2. Xbox 360 Preventative Maintenance, Clean your Xbox 360: 2 단계, 이미지 1개 중 1개
      • All electronics with a fan (or even without one) collect dust over time.
      • This dust can eventually clog the heatsinks and/or fans, causing your Xbox 360 to be noisy or overheat.
      • Follow this guide up to (and including) step 35. Clean the fans, motherboard, and all of the casing with high purity (90+%) isopropyl alcohol, and blow out the dust from the heat sinks with compressed air. Then reassemble your Xbox 360.
      댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 55명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
WiredExtreme
회원 가입일: 08/30/10
2,531 평판
안내서 1개를 작성함
5가이드 댓글
This guide should have steps and cover a single topic. You should split this guide in two, one for how to store the Xbox in a well ventilated area (not just examples, but directions) and another for how to clean the heat sink. The best guides can be referenced in any context and are detailed instructions to reach a goal, as opposed to guidelines or examples of proper use. Good idea though, preventing issues is better than solving them!
Alex Jansen - 답글 공유
Good points made by Alex.
Most obviously, where should you blow into the xbox to clear out the dust? A couple red circles around the best holes to stick the straw into to blow out the dust would be very helpful.
maccentric - 답글 공유
I would also highly suggest leaving it laying down & using a USB powered dual or more fan laptop cooling unit. I have a 2nd gen I bought in 03.2005 that it still working beautifully!
Gekko8 - 답글 공유
One should also take into consideration that dust and overheating are not truly the cause of a RRoD error unless it's simply overheating. I've reballed plenty on consoles, as new as 2009, with no dust whatsoever in the system. I've also done tray cleaning and lubrication on consoles that were filled with thick layers of dust without ever red ringing.
Mark - 답글 공유
You should never use pressurized air, you will be blowing dust and tiny particles deeper into your system. lets put it this way, a particle of smoke is enough to destroy a hard drive. Use a vacumm.
jake - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 41
지난 30일: 859
전체 시간: 53,994
