주요 콘텐츠로 건너뛰기
Xbox Elite Wireless Controller Series 2 Top Housing Replacement
Manuel Haeussermann
Manuel Haeussermann다른 한 명의 기여자
최종 수정일 June 21, 2024
10 - 20 분
쉬움
Use this guide to replace the top housing on your Xbox Elite Wireless Controller Series 2.
The top housing may need to be replaced if it's cracked, or you may be installing a new, customized one. The top housing is sometimes called a faceplate or top shell.
필요한 것
도구
  1. Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Remove the thumbstick toppers: 1 단계, 이미지 3개 중 1개 Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Remove the thumbstick toppers: 1 단계, 이미지 3개 중 2개 Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Remove the thumbstick toppers: 1 단계, 이미지 3개 중 3개
    • Use your fingers to remove the thumbstick toppers.
  2. Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Remove the D-pad cover: 2 단계, 이미지 2개 중 1개 Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Remove the D-pad cover: 2 단계, 이미지 2개 중 2개
    • Use your fingers to remove the D-pad cover.
  3. Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Disassembly information: 3 단계, 이미지 2개 중 1개 Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Disassembly information: 3 단계, 이미지 2개 중 2개
    • The top housing is secured in two ways:
    • 13 tight plastic clips
    • Several strips of adhesive tape
  4. Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Release the top housing clips: 4 단계, 이미지 3개 중 1개 Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Release the top housing clips: 4 단계, 이미지 3개 중 2개 Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Release the top housing clips: 4 단계, 이미지 3개 중 3개
    • Releasing the plastic clips requires significant force. Take your time to avoid damaging your controller.
    • Insert an opening tool between the left bumper and the top housing.
    • Pry up the top housing to release the top left clip.
  5. Xbox Elite Wireless Controller Series 2 Top Housing Replacement: 5 단계, 이미지 2개 중 1개 Xbox Elite Wireless Controller Series 2 Top Housing Replacement: 5 단계, 이미지 2개 중 2개
    • Insert an opening tool into the seam between the two housings on the controller’s left edge.
  6. Xbox Elite Wireless Controller Series 2 Top Housing Replacement: 6 단계, 이미지 3개 중 1개 Xbox Elite Wireless Controller Series 2 Top Housing Replacement: 6 단계, 이미지 3개 중 2개 Xbox Elite Wireless Controller Series 2 Top Housing Replacement: 6 단계, 이미지 3개 중 3개
    • Slide the opening tool along the left edge and pry up intermittently to release the plastic clips.
  7. Xbox Elite Wireless Controller Series 2 Top Housing Replacement: 7 단계, 이미지 3개 중 1개 Xbox Elite Wireless Controller Series 2 Top Housing Replacement: 7 단계, 이미지 3개 중 2개 Xbox Elite Wireless Controller Series 2 Top Housing Replacement: 7 단계, 이미지 3개 중 3개
    • Insert your opening tool into the seam between the two housings on the inner left edge.
    • Slide the opening tool along the bottom edge and pry up intermittently to release the plastic clips.
  8. Xbox Elite Wireless Controller Series 2 Top Housing Replacement: 8 단계, 이미지 3개 중 1개 Xbox Elite Wireless Controller Series 2 Top Housing Replacement: 8 단계, 이미지 3개 중 2개 Xbox Elite Wireless Controller Series 2 Top Housing Replacement: 8 단계, 이미지 3개 중 3개
    • Insert your opening tool into the seam between the two housings on the controller’s right edge.
    • Slide the opening tool along the right edge and pry up intermittently to release the plastic clips.
  9. Xbox Elite Wireless Controller Series 2 Top Housing Replacement: 9 단계, 이미지 2개 중 1개 Xbox Elite Wireless Controller Series 2 Top Housing Replacement: 9 단계, 이미지 2개 중 2개
    • Insert your opening tool between the right bumper and the top housing.
    • Pry up the top housing to release the remaining plastic clips.
  10. Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Remove the top housing: 10 단계, 이미지 3개 중 1개 Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Remove the top housing: 10 단계, 이미지 3개 중 2개 Xbox Elite Wireless Controller Series 2 Top Housing Replacement, Remove the top housing: 10 단계, 이미지 3개 중 3개
    • Remove the top housing.
    • To reinstall the top housing, position it on the midframe assembly and press down firmly along the edges to engage all of the clips.
결론
다른 14명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Manuel Haeussermann
회원 가입일: 07/13/22
19,476 평판
안내서 71개를 작성함
iFixit iFixit 회원
Staff
118 회원들
안내서 19,470개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 112
지난 30일: 442
전체 시간: 12,353
