주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xbox One S All Digital Edition Fan Replacement
필요한 것
  1. Xbox One S All Digital Edition Fan Replacement, Plastic Enclosure: 1 단계, 이미지 3개 중 1개 Xbox One S All Digital Edition Fan Replacement, Plastic Enclosure: 1 단계, 이미지 3개 중 2개 Xbox One S All Digital Edition Fan Replacement, Plastic Enclosure: 1 단계, 이미지 3개 중 3개
    • Position the iFixit Opening Tool's riveted edge in between the top and bottom cover of the plastic enclosure.
    • Apply downward pressure on the iFixit Opening Tool until the security clip unlocks.
    • Repeat on different points of the plastic enclosure until the bottom cover is removed.
    댓글 쓰기
  2. Xbox One S All Digital Edition Fan Replacement: 2 단계, 이미지 2개 중 1개 Xbox One S All Digital Edition Fan Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the six 50 mm green screws (labeled F1-F6) from the metal chassis using a Torx 10 screwdriver.
    • These screws hold the top cover of the plastic enclosure to the chassis.
    댓글 쓰기
  3. Xbox One S All Digital Edition Fan Replacement: 3 단계, 이미지 2개 중 1개 Xbox One S All Digital Edition Fan Replacement: 3 단계, 이미지 2개 중 2개
    • Apply pressure to peel off the sides of the casing.
    • Separate the metal chassis from the top cover, lifting the back of the chassis up and away from the top cover.
    • The plastic back panel is meant to stay attached to the metal chassis.
    댓글 쓰기
  4. Xbox One S All Digital Edition Fan Replacement: 4 단계, 이미지 1개 중 1개
    • Flip the metal enclosure so that the fan cover is on top.
    댓글 쓰기
  5. Xbox One S All Digital Edition Fan Replacement, Top Metal Shield: 5 단계, 이미지 2개 중 1개 Xbox One S All Digital Edition Fan Replacement, Top Metal Shield: 5 단계, 이미지 2개 중 2개
    • Remove the two 15mm screws from the front panel using the Torx T8 screwdriver.
    댓글 쓰기
  6. Xbox One S All Digital Edition Fan Replacement: 6 단계, 이미지 3개 중 1개 Xbox One S All Digital Edition Fan Replacement: 6 단계, 이미지 3개 중 2개 Xbox One S All Digital Edition Fan Replacement: 6 단계, 이미지 3개 중 3개
    • Carefully slide the top metal case off the frame.
    • This may require shifting the case side to side as you slide up.
    댓글 쓰기
  7. Xbox One S All Digital Edition Fan Replacement, IR Blaster: 7 단계, 이미지 2개 중 1개 Xbox One S All Digital Edition Fan Replacement, IR Blaster: 7 단계, 이미지 2개 중 2개
    • Remove the four 15mm screws attaching the IR Blaster to the metal chassis with the Torx T8 Security screwdriver.
    댓글 쓰기
  8. Xbox One S All Digital Edition Fan Replacement: 8 단계, 이미지 2개 중 1개 Xbox One S All Digital Edition Fan Replacement: 8 단계, 이미지 2개 중 2개
    • Carefully remove the IR Blaster from the metal chassis.
    • The connector is very fragile. Make sure you pull the board away from the case and not sideways.
    댓글 쓰기
  9. Xbox One S All Digital Edition Fan Replacement, Wifi Card: 9 단계, 이미지 2개 중 1개 Xbox One S All Digital Edition Fan Replacement, Wifi Card: 9 단계, 이미지 2개 중 2개
    • Remove the three 15 mm screws with the Torx T8 Security Bit Screwdriver.
    • The top of the metal chassis has been removed in the picture, but is not necessary for the replacement.
    댓글 쓰기
  10. Xbox One S All Digital Edition Fan Replacement: 10 단계, 이미지 1개 중 1개
    • Carefully remove the WiFi Card from the metal chassis.
    댓글 쓰기
  11. Xbox One S All Digital Edition Fan Replacement, Bottom Metal Shield: 11 단계, 이미지 2개 중 1개 Xbox One S All Digital Edition Fan Replacement, Bottom Metal Shield: 11 단계, 이미지 2개 중 2개
    • Remove the eight 10mm screws from the bottom of the metal casing using the Torx T9 screwdriver.
    • Remove the four 15mm screws from the bottom of the heatsink fastener using the Torx T8 screwdriver.
    댓글 쓰기
  12. Xbox One S All Digital Edition Fan Replacement: 12 단계, 이미지 3개 중 1개 Xbox One S All Digital Edition Fan Replacement: 12 단계, 이미지 3개 중 2개 Xbox One S All Digital Edition Fan Replacement: 12 단계, 이미지 3개 중 3개
    • Remove the two plastic pieces from the motherboard.
    댓글 쓰기
  13. Xbox One S All Digital Edition Fan Replacement: 13 단계, 이미지 3개 중 1개 Xbox One S All Digital Edition Fan Replacement: 13 단계, 이미지 3개 중 2개 Xbox One S All Digital Edition Fan Replacement: 13 단계, 이미지 3개 중 3개
    • Lift the motherboard up from the metal chassis.
    • The motherboard should easily separate from the metal chassis.
    댓글 쓰기
  14. Xbox One S All Digital Edition Fan Replacement, Fan: 14 단계, 이미지 2개 중 1개 Xbox One S All Digital Edition Fan Replacement, Fan: 14 단계, 이미지 2개 중 2개
    • Locate the 4-pin connector on the side of the fan assembly.
    • Disconnect the cable from the motherboard.
    댓글 쓰기
  15. Xbox One S All Digital Edition Fan Replacement: 15 단계, 이미지 2개 중 1개 Xbox One S All Digital Edition Fan Replacement: 15 단계, 이미지 2개 중 2개
    • Use a spudger to pry the fan tabs up and away from the heatsink.
    • Getting the fan detached can take some force. A metal tool might be required.
    댓글 쓰기
  16. Xbox One S All Digital Edition Fan Replacement: 16 단계, 이미지 2개 중 1개 Xbox One S All Digital Edition Fan Replacement: 16 단계, 이미지 2개 중 2개
    • Lift the fan away to fully remove it.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 8명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jules Hajjar
회원 가입일: 10/10/19
2,122 평판
안내서 8개를 작성함
Cal Poly, Team S12-G6, Regan Fall 2019 Cal Poly, Team S12-G6, Regan Fall 2019 회원
CPSU-REGAN-F19S12G6
4 회원들
안내서 32개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 62
지난 30일: 286
전체 시간: 12,853
