주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xbox One Wireless Controller Bottom Motherboard Replacement
필요한 것
  1. Xbox One Wireless Controller Bottom Motherboard Replacement, Battery Pack: 1 단계, 이미지 1개 중 1개
    • Remove the battery pack cover.
    • Remove batteries.
    댓글 쓰기
  2. Xbox One Wireless Controller Bottom Motherboard Replacement, Side Handles: 2 단계, 이미지 2개 중 1개 Xbox One Wireless Controller Bottom Motherboard Replacement, Side Handles: 2 단계, 이미지 2개 중 2개
    • We recommend using a nylon spudger for this step. A metal spudger is shown.
    • Grip the controller firmly to remove the side handles, wedging a spudger into the seam between the front and handle plates.
    • Pry the side plate away from the front plate by moving the spudger back and forth. You will need to do this all the way around the side plate's seam.
    댓글 쓰기
  3. Xbox One Wireless Controller Bottom Motherboard Replacement, Screws: 3 단계, 이미지 2개 중 1개 Xbox One Wireless Controller Bottom Motherboard Replacement, Screws: 3 단계, 이미지 2개 중 2개
    • There is a hidden screw located in the middle of the controller behind the label.
    • Use a screwdriver and punch a hole directly in the center of the label.
    • You may also lift the label if you do not want to puncture it.
    • Remove the five 10mm screws located on the back of the controller using the TR8 Security Torx Screwdriver.
    댓글 쓰기
  4. Xbox One Wireless Controller Bottom Motherboard Replacement, Backplate: 4 단계, 이미지 1개 중 1개
    • Remove the backplate.
    댓글 쓰기
  5. Xbox One Wireless Controller Bottom Motherboard Replacement, Faceplate: 5 단계, 이미지 1개 중 1개
    • Remove the faceplate.
    댓글 쓰기
  6. Xbox One Wireless Controller Bottom Motherboard Replacement, Top Motherboard: 6 단계, 이미지 2개 중 1개 Xbox One Wireless Controller Bottom Motherboard Replacement, Top Motherboard: 6 단계, 이미지 2개 중 2개
    • You may let the rumble motors hang freely out of their sockets.
    • De-solder the soldered joints while holding the red and black wires down on the top motherboard.
    • De-solder the black and gray wires that are attached to the top motherboard.
    • Remove the rumble motors and set them aside.
    • Be careful while using the soldering iron not to damage other components or hurt yourself.
    • For information on how to solder, click here.
    댓글 쓰기
  7. Xbox One Wireless Controller Bottom Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Unscrew the two 7mm T6 screws located near the rumble motor sockets.
    댓글 쓰기
  8. Xbox One Wireless Controller Bottom Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • Firmly grip sides of motherboard near the middle.
    • Lift upwards while slightly wiggling the motherboard forward and backward.
    • Lifting the motherboard will require some force.
    댓글 쓰기
  9. Xbox One Wireless Controller Bottom Motherboard Replacement, Trigger Rumble Motors: 9 단계, 이미지 1개 중 1개
    • Remove the yellow tape holding the wires in place on the front of the controller.
    댓글 쓰기
  10. Xbox One Wireless Controller Bottom Motherboard Replacement: 10 단계, 이미지 3개 중 1개 Xbox One Wireless Controller Bottom Motherboard Replacement: 10 단계, 이미지 3개 중 2개 Xbox One Wireless Controller Bottom Motherboard Replacement: 10 단계, 이미지 3개 중 3개
    • Unscrew the two 7mm T6 Hex screws located on underside the triggers.
    댓글 쓰기
  11. Xbox One Wireless Controller Bottom Motherboard Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the trigger covers.
    댓글 쓰기
  12. Xbox One Wireless Controller Bottom Motherboard Replacement: 12 단계, 이미지 1개 중 1개
    • Desolder the wires from the motherboard.
    • Remove the rumble motors from its socket and pull the wire with it.
    댓글 쓰기
  13. Xbox One Wireless Controller Bottom Motherboard Replacement, Bottom Motherboard: 13 단계, 이미지 2개 중 1개 Xbox One Wireless Controller Bottom Motherboard Replacement, Bottom Motherboard: 13 단계, 이미지 2개 중 2개
    • Remove the six T6 Torx screws located on the bottom motherboard.
    댓글 쓰기
  14. Xbox One Wireless Controller Bottom Motherboard Replacement: 14 단계, 이미지 2개 중 1개 Xbox One Wireless Controller Bottom Motherboard Replacement: 14 단계, 이미지 2개 중 2개
    • Remove the bumpers by prying them off of the pegs that secure them, using a spudger. They are located on the front and back of the controller.
    • A standard nylon spudger is recommended for this step. Using a metal spudger near the motherboard as shown risks damaging your device.
    댓글 쓰기
  15. Xbox One Wireless Controller Bottom Motherboard Replacement: 15 단계, 이미지 2개 중 1개 Xbox One Wireless Controller Bottom Motherboard Replacement: 15 단계, 이미지 2개 중 2개
    • Lift the piece surrounding the Home button off of its pegs.
    • Pry it off of the other side, using a spudger on the pins.
    • Removing this piece may require a lot of force.
    댓글 쓰기
  16. Xbox One Wireless Controller Bottom Motherboard Replacement: 16 단계, 이미지 1개 중 1개
    • Remove the bottom motherboard.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 31명이 해당 안내서를 완성하였습니다.
작성자
13다른 기여자 명과 함께
Liam Gow
회원 가입일: 01/22/15
5,594 평판
안내서 3개를 작성함
Cal Poly, Team 20-15, Maness Winter 2015 Cal Poly, Team 20-15, Maness Winter 2015 회원
CPSU-MANESS-W15S20G15
5 회원들
안내서 54개를 작성함
11가이드 댓글
Is de-soldering optional?
John Gonzalez - 답글 공유
Considering the placement of wires attached by solder on both sides of the top board, it would be quite difficult to reach anything beneath it otherwise. I suppose it depends on what you're trying to achieve.
In any case, you might as well try to move it without desoldering if desoldering is going to be an issue. Make sure not to pull hard, though.
Liam Gow - 답글 공유
I have a question... Will the motherboard you can get at the store here work it the newer controllers with built in headphone jack?
ETHREAL1 - 답글 공유
I would expect not, I'm afraid. The motherboards will probably have different circuitry, even if the shapes are the same, which they may not be.
Liam Gow - 답글 공유
The position/mounting of the LB and RB buttons on the motherboard piece between the day-one/sans-jack and the newer 3.5mm jack (non-Slim) boards are completely different.
The older revision motherboard has the mountings inverted (pointing downwards to the south end-headset attachment port- of the controller) compared to the newer ones.
The newer ones have the circuit with the bumper buttons mounted pointing to the north end toward the bumpers on the top of the controller.
icho - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 59
지난 30일: 298
전체 시간: 67,889
