주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xbox One Wireless Controller Model 1708 Top Motherboard Replacement
필요한 것
  1. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Cover Plate: 1 단계, 이미지 2개 중 1개 Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Cover Plate: 1 단계, 이미지 2개 중 2개
    • Slide the battery cover toward the top of the controller to remove it.
    • Lift up the batteries or the battery pack from the battery compartment.
    댓글 쓰기
  2. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Xbox One Wireless Controller Model 1708 Top Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Insert a plastic opening tool into the top seam, and gently work the opening tool to the bottom of the controller.
    • Continue using the opening tool to gently pry the side plate off of the controller.
    • Repeat this process for the second side plate.
    댓글 쓰기
  3. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Gently peel the battery label or punch a hole in the center of the sticker in the battery compartment to reveal the hidden screw.
    • Remove the five 9mm torx-9 security screws from the back of the controller.
    댓글 쓰기
  4. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Xbox One Wireless Controller Model 1708 Top Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Orient the controller so the front plate is facing up.
    • Lift the front cover off of the controller.
    댓글 쓰기
  5. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • Turn the controller face down and gently lift the rear plate.
    • Be careful with the rumble motors, as they tend to fall out, risking damage to the motherboard.
    댓글 쓰기
  6. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Tape Shock Motors in place: 6 단계, 이미지 3개 중 1개 Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Tape Shock Motors in place: 6 단계, 이미지 3개 중 2개 Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Tape Shock Motors in place: 6 단계, 이미지 3개 중 3개
    • Tape the Rumbler/shock motors in place.
    • This will prevent the motors from falling out.
    댓글 쓰기
  7. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Directional Pad: 7 단계, 이미지 1개 중 1개
    • Turn the device over and remove the directional pad by gently pulling it away from the controller.
    댓글 쓰기
  8. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Joystick Caps: 8 단계, 이미지 1개 중 1개
    • Pull the joysticks off of the controller.
    댓글 쓰기
  9. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, Top Motherboard: 9 단계, 이미지 1개 중 1개
    • If the rumble motors fall out of frame, the wires may disconnect from the motherboard . The wires will have to be soldered to reattach the motor.
    • Turn the device over and remove the two 7mm torx-6 screws in the bottom left and right corners.
    댓글 쓰기
  10. Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, De-soldering required: 10 단계, 이미지 3개 중 1개 Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, De-soldering required: 10 단계, 이미지 3개 중 2개 Xbox One Wireless Controller Model 1708 Top Motherboard Replacement, De-soldering required: 10 단계, 이미지 3개 중 3개
    • Firmly grasp the top and bottom motherboards in opposite hands, then gently pull them apart.
    • The top motherboard is still connected to the bottom motherboard. To fully separate the top motherboard, you will need to use a soldering iron.
    • Warning: Do not attempt to disconnect the shielded (gold colored) connector as it is extremely fragile you will break it. It runs between the two boards.
    • De-solder the shielded cable from the lower board instead of attempting to disconnect the connector. De-solder using micro soldering techniquest.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 25명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Lien (Ally) Quan
회원 가입일: 09/25/17
1,095 평판
안내서 1개를 작성함
Cal Poly, Team S18-G3, Forte Fall 2017 Cal Poly, Team S18-G3, Forte Fall 2017 회원
CPSU-FORTE-F17S18G3
4 회원들
안내서 42개를 작성함
1가이드 댓글
Necesito un diagrama donde pueda ver el esquemático de los vibradores del gatillo
Héctor Bohórquez - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 14
지난 7일: 76
지난 30일: 398
전체 시간: 36,230
