주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xbox One X Disc Drive Replacement
필요한 것
동영상 개요
  1. Xbox One X Disc Drive Replacement, Remove the sticker: 1 단계, 이미지 2개 중 1개 Xbox One X Disc Drive Replacement, Remove the sticker: 1 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Before starting this guide: Turn off the device. Then, unplug any cables from the console.
    • Use blunt tweezers to peel off the sticker covering the right-side screw on the back of the console.
    댓글 쓰기
  2. Xbox One X Disc Drive Replacement, Remove the external screws: 2 단계, 이미지 1개 중 1개
    • Use a T10 Torx screwdriver to remove the two 12.6 mm–long screws located on the back of the console.
    댓글 쓰기
  3. Xbox One X Disc Drive Replacement, Slide the upper case horizontally: 3 단계, 이미지 2개 중 1개 Xbox One X Disc Drive Replacement, Slide the upper case horizontally: 3 단계, 이미지 2개 중 2개
    • Rotate the console 90 degrees.
    • Pull the front of the upper plastic case horizontally toward the front of the console until it comes to a stop. This slides the clips out of the slots on the upper plastic case.
    댓글 쓰기
  4. Xbox One X Disc Drive Replacement, Lift the upper case off the lower case: 4 단계, 이미지 2개 중 1개 Xbox One X Disc Drive Replacement, Lift the upper case off the lower case: 4 단계, 이미지 2개 중 2개
    • Rotate the console 90 degrees so that the back is facing you.
    • Lift up the left side of the upper plastic case (as viewed from the back of the console), stopping when it won’t lift any further.
    댓글 쓰기
  5. Xbox One X Disc Drive Replacement: 5 단계, 이미지 3개 중 1개 Xbox One X Disc Drive Replacement: 5 단계, 이미지 3개 중 2개 Xbox One X Disc Drive Replacement: 5 단계, 이미지 3개 중 3개
    • While continuing to hold the left side of the upper plastic case, push up on the right side to move the right-side screw boss out of the way.
    • If pushing up on the case doesn't work, try moving it in different directions until it can swing open.
    • Swing the upper plastic case open to 75 degrees.
    댓글 쓰기
  6. Xbox One X Disc Drive Replacement: 6 단계, 이미지 2개 중 1개 Xbox One X Disc Drive Replacement: 6 단계, 이미지 2개 중 2개
    • Push the upper plastic case down and away from the console to remove it completely.
    댓글 쓰기
  7. Xbox One X Disc Drive Replacement, Disconnect the ribbon cable: 7 단계, 이미지 3개 중 1개 Xbox One X Disc Drive Replacement, Disconnect the ribbon cable: 7 단계, 이미지 3개 중 2개 Xbox One X Disc Drive Replacement, Disconnect the ribbon cable: 7 단계, 이미지 3개 중 3개
    • Use the pointed end of a spudger, an opening tool, or your fingernail to flip down the small, hinged locking flap on the ribbon cable ZIF connector on the front circuit board.
    댓글 쓰기
  8. Xbox One X Disc Drive Replacement, Disconnect the ribbon cable: 8 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use blunt tweezers to pull the ribbon cable down out of the connector.
    댓글 쓰기
  9. Xbox One X Disc Drive Replacement, Remove the front circuit board screws: 9 단계, 이미지 1개 중 1개
    • Use a T8 Torx screwdriver to remove the three 13.3 mm screws securing the front circuit board to the upper metal case.
    댓글 쓰기
  10. Xbox One X Disc Drive Replacement, Remove the front circuit board: 10 단계, 이미지 2개 중 1개 Xbox One X Disc Drive Replacement, Remove the front circuit board: 10 단계, 이미지 2개 중 2개
    • Pull the front circuit board straight out away from the upper metal case and set it aside.
    • Grip the board on either side of where it is plugged in to avoid bending and damaging it.
    댓글 쓰기
  11. Xbox One X Disc Drive Replacement, Remove the upper metal case screws: 11 단계, 이미지 1개 중 1개
    • Use a T10 Torx screwdriver to remove the six 47.7 mm screws securing the upper metal case to the lower plastic case.
    • Use a T8 Torx screwdriver to remove the two 7.5 mm screws securing the press connector to the upper metal case.
    댓글 쓰기
  12. Xbox One X Disc Drive Replacement, Detach the press connector: 12 단계, 이미지 2개 중 1개 Xbox One X Disc Drive Replacement, Detach the press connector: 12 단계, 이미지 2개 중 2개
    • Insert the flat end of a spudger underneath the press connector on the side opposite of the ribbon cable.
    • Use the spudger to lift the press connector up and away from the upper metal case.
    • Don't push the spudger all the way to the socket. Prying up the socket may damage it.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    댓글 쓰기
  13. Xbox One X Disc Drive Replacement, Remove the lower plastic case: 13 단계, 이미지 3개 중 1개 Xbox One X Disc Drive Replacement, Remove the lower plastic case: 13 단계, 이미지 3개 중 2개 Xbox One X Disc Drive Replacement, Remove the lower plastic case: 13 단계, 이미지 3개 중 3개
    • Flip the console over.
    • Hold on to the lower plastic case because it is no longer attached to the metal case.
    • Lift the lower plastic case up from the metal case and set it aside.
    댓글 쓰기
  14. Xbox One X Disc Drive Replacement, Remove the lower metal case screws: 14 단계, 이미지 1개 중 1개
    • Remove the two T10 Torx screws securing the lower metal case:
    • One 7.7 mm screw
    • One 11.4 mm screw
    댓글 쓰기
  15. Xbox One X Disc Drive Replacement, Remove the lower metal case: 15 단계, 이미지 1개 중 1개
    • Lift the lower metal case up off the upper metal case and internal components.
    • The disc drive may lift up with the lower metal case. Hold it down during this step.
    • Set the lower metal case aside.
    댓글 쓰기
  16. Xbox One X Disc Drive Replacement, Unscrew the power supply: 16 단계, 이미지 1개 중 1개
    • The disc drive is only attached to the motherboard by two cable connectors. Hold the disc drive when flipping the console over to avoid damaging it.
    • Use a T10 Torx screwdriver to remove the two 11.4 mm screws securing the power supply to the upper metal case
    댓글 쓰기
  17. Xbox One X Disc Drive Replacement, Loosen the disc drive: 17 단계, 이미지 2개 중 1개 Xbox One X Disc Drive Replacement, Loosen the disc drive: 17 단계, 이미지 2개 중 2개
    • Lift the disc drive so that its metal tab is unhooked from the power supply.
    • The disc drive is plugged into the motherboard. Don’t bend the wires more than necessary to avoid damaging them.
    • Place the disc drive on the upper metal case so that it sits over the hard drive. You'll need enough space to unplug the power supply from the motherboard.
    댓글 쓰기
  18. Xbox One X Disc Drive Replacement, Unstick the foam tape on the power supply: 18 단계, 이미지 3개 중 1개 Xbox One X Disc Drive Replacement, Unstick the foam tape on the power supply: 18 단계, 이미지 3개 중 2개 Xbox One X Disc Drive Replacement, Unstick the foam tape on the power supply: 18 단계, 이미지 3개 중 3개
    • Insert the flat end of the spudger underneath the dark grey foam tape starting at the corner closest to the power supply and edge of the console.
    • Lift up the corner.
    • Slowly push the spudger through to the other side of the tape until you can see the flat end emerge.
    • Remove the spudger slowly. There are two grey cables underneath the foam tape. Try to avoid hitting them with the spudger so that you don't damage them.
    댓글 쓰기
  19. Xbox One X Disc Drive Replacement, Unplug the power supply: 19 단계, 이미지 2개 중 1개 Xbox One X Disc Drive Replacement, Unplug the power supply: 19 단계, 이미지 2개 중 2개
    • Lift the power supply directly upward to unplug it from the motherboard.
    • Move the disc drive further away from the power supply if you need more space.
    댓글 쓰기
  20. Xbox One X Disc Drive Replacement, Set the power supply to the side: 20 단계, 이미지 3개 중 1개 Xbox One X Disc Drive Replacement, Set the power supply to the side: 20 단계, 이미지 3개 중 2개 Xbox One X Disc Drive Replacement, Set the power supply to the side: 20 단계, 이미지 3개 중 3개
    • After the power supply is unplugged from the motherboard, rotate and lift it away from the console.
    • The two grey cables are still attached to the console by the dark grey foam tape and the power supply socket beneath the fan case. Avoid bending the cables more than necessary to prevent damage.
    • Place the power supply so that it is sitting on its side just outside the upper metal case.
    댓글 쓰기
  21. Xbox One X Disc Drive Replacement, Unplug the disc drive: 21 단계, 이미지 2개 중 1개 Xbox One X Disc Drive Replacement, Unplug the disc drive: 21 단계, 이미지 2개 중 2개
    • Unplug the SATA cable connecting the disc drive to the motherboard by pulling directly upward.
    댓글 쓰기
  22. Xbox One X Disc Drive Replacement: 22 단계, 이미지 2개 중 1개 Xbox One X Disc Drive Replacement: 22 단계, 이미지 2개 중 2개
    • Unplug the bundled cable connector connecting the disc drive to the motherboard by pulling directly upward.
    댓글 쓰기
  23. Xbox One X Disc Drive Replacement, Remove the disc drive: 23 단계, 이미지 1개 중 1개
    • Lift the disc drive out of the console.
    댓글 쓰기
  24. Xbox One X Disc Drive Replacement, Remove the vibration dampener: 24 단계, 이미지 3개 중 1개 Xbox One X Disc Drive Replacement, Remove the vibration dampener: 24 단계, 이미지 3개 중 2개 Xbox One X Disc Drive Replacement, Remove the vibration dampener: 24 단계, 이미지 3개 중 3개
    • Slide the rubber vibration dampener off of the disc drive.
    댓글 쓰기
  25. Xbox One X Disc Drive Replacement, Remove the external disc drive connectors: 25 단계, 이미지 2개 중 1개 Xbox One X Disc Drive Replacement, Remove the external disc drive connectors: 25 단계, 이미지 2개 중 2개
    • Unplug the bundled cable connector from the disc drive.
    댓글 쓰기
  26. Xbox One X Disc Drive Replacement: 26 단계, 이미지 2개 중 1개 Xbox One X Disc Drive Replacement: 26 단계, 이미지 2개 중 2개
    • Unplug the SATA cable from the disc drive.
    댓글 쓰기
  27. Xbox One X Disc Drive Replacement, Remove the cover: 27 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the four 3.7 mm screws securing the disc drive cover.
    • You don't need to remove the foam covering the two right-side screws. Move the foam aside just enough to expose the screw.
    댓글 쓰기
  28. Xbox One X Disc Drive Replacement: 28 단계, 이미지 2개 중 1개 Xbox One X Disc Drive Replacement: 28 단계, 이미지 2개 중 2개
    • Remove the cover from the disc drive.
    댓글 쓰기
  29. Xbox One X Disc Drive Replacement, Disconnect the three ZIF connectors: 29 단계, 이미지 2개 중 1개 Xbox One X Disc Drive Replacement, Disconnect the three ZIF connectors: 29 단계, 이미지 2개 중 2개
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the large ribbon cable ZIF connector.
    댓글 쓰기
  30. Xbox One X Disc Drive Replacement: 30 단계, 이미지 2개 중 1개 Xbox One X Disc Drive Replacement: 30 단계, 이미지 2개 중 2개
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the small ribbon cable next to the large ribbon cable ZIF connector.
    댓글 쓰기
  31. Xbox One X Disc Drive Replacement: 31 단계, 이미지 2개 중 1개 Xbox One X Disc Drive Replacement: 31 단계, 이미지 2개 중 2개
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the long ribbon cable in the corner of the disc drive ZIF connector.
    댓글 쓰기
  32. Xbox One X Disc Drive Replacement: 32 단계, 이미지 3개 중 1개 Xbox One X Disc Drive Replacement: 32 단계, 이미지 3개 중 2개 Xbox One X Disc Drive Replacement: 32 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use blunt tweezers to pull out each of the three ribbon cables in the direction of the cable.
    댓글 쓰기
  33. Xbox One X Disc Drive Replacement, Desolder the two wires: 33 단계, 이미지 2개 중 1개 Xbox One X Disc Drive Replacement, Desolder the two wires: 33 단계, 이미지 2개 중 2개
    • Use a soldering iron to desolder the red wire in the corner of the disc drive circuit board.
    • Then, desolder the adjacent black wire. Use blunt tweezers to hold and pull away the wires from the circuit board.
    • Follow general soldering safety guidelines such as wearing eye protection, working in a well-ventilated area, and washing your hands with soap and water after soldering.
    • Excessive heat may damage electrical components. Don't apply the soldering iron to the board for long amounts of time.
    • When you install the original circuit board into the replacement disc drive, solder the red wire to the solder pad labeled "R." Solder the black wire to the solder pad labeled "B."
    댓글 쓰기
  34. Xbox One X Disc Drive Replacement, Remove the circuit board screws: 34 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the three 3.4 mm screws securing the circuit board to the disc drive case.
    댓글 쓰기
  35. Xbox One X Disc Drive Replacement, Remove the disc drive circuit board: 35 단계, 이미지 2개 중 1개 Xbox One X Disc Drive Replacement, Remove the disc drive circuit board: 35 단계, 이미지 2개 중 2개
    • Lift the circuit board out of the disc drive case and transfer it to the replacement drive.
    댓글 쓰기
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Xbox One X Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 22명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Kyle Smith
회원 가입일: 02/01/21
52,544 평판
안내서 124개를 작성함
3가이드 댓글
I bought a One X for cheap and it worked but the Disc drive didn't - it couldn't pull in the discs; I opened it up, discovered that it was very dusty, cleaned that out and also cleaned the Disc drive, especially the rollers of the mechanism that pushes the disc out or pulls it in, of course also the laser lens, then reassembled it and it works absolutely fine again.
Marcel Pape - 답글 공유
Ive replaced the dvd drive with mine but the game discs will not load
David Chan - 답글 공유
would it work if i got the Disc drive from my old xbox one ? i think they are the same exact size though !
AbuObaid Home - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 44
지난 7일: 167
지난 30일: 737
전체 시간: 43,835
