Xbox Series S Fan Replacement
Follow this guide to remove and replace the fan on a Xbox Series S.
이 단계에 사용된 도구:Tweezers$4.99
Use tweezers to peel off the two white screw covers located on the bottom corners of the back panel.
이 단계에 사용된 도구:Magnetic Project Mat$19.95
Use a T8 Torx driver to remove the two 10 mm-long screws securing the back panel to the bottom panel.
Slide the bottom panel horizontally toward the back of the console until it comes to a stop.
Lift straight up and remove the bottom panel from the plastic case.
Use a T10 Torx driver to remove the seven 51 mm-long screws securing the chassis to the plastic case.
With the bottom of the Xbox facing you, pull the two bottom-rear corners of the plastic case away from each other.
As you pull the corners apart, slide the back panel towards the bottom of the device. This releases the back panel from the plastic case.
Use a T10 Torx driver to remove the seven 11.3 mm-long screws securing the power supply to the chassis.
Flip the device over.
Lift the upper chassis straight up to remove it.
Lift the power supply straight up to disconnect it from the motherboard.
Remove the power supply.
Use a T10 Torx driver to remove the two 11.3 mm-long screws securing the fan to the chassis.
Use your fingers to pull and disconnect the fan connector from its motherboard socket.
다른 19명이 해당 안내서를 완성하였습니다.
댓글 2개
Hi wondering if I’m able to switch out the fan to another fan like a noctua fan but I don’t know what fab size?
