주요 콘텐츠로 건너뛰기
Xbox Series X|S Controller (Model 1914) Right Handle Cover Replacement
Manuel Haeussermann
Manuel Haeussermann
최종 수정일 August 14, 2024
5 - 10 분
조정
Use this guide to replace the right handle cover on your Xbox Series X|S Controller (model 1914).
필요한 것
도구
  1. Xbox Series X|S Controller (Model 1914) Right Handle Cover Replacement, Insert an opening tool: 1 단계, 이미지 3개 중 1개 Xbox Series X|S Controller (Model 1914) Right Handle Cover Replacement, Insert an opening tool: 1 단계, 이미지 3개 중 2개 Xbox Series X|S Controller (Model 1914) Right Handle Cover Replacement, Insert an opening tool: 1 단계, 이미지 3개 중 3개
    • Insert an opening tool between the right handle cover and the bottom inner edge of the back housing.
  2. Xbox Series X|S Controller (Model 1914) Right Handle Cover Replacement, Release the right handle cover clips: 2 단계, 이미지 3개 중 1개 Xbox Series X|S Controller (Model 1914) Right Handle Cover Replacement, Release the right handle cover clips: 2 단계, 이미지 3개 중 2개 Xbox Series X|S Controller (Model 1914) Right Handle Cover Replacement, Release the right handle cover clips: 2 단계, 이미지 3개 중 3개
    • Strong plastic clips secure the handle cover. Significant force is required to release them.
    • Slide the opening tool along the inner edge of the right handle cover and pry intermittently to release the plastic clips.
  3. Xbox Series X|S Controller (Model 1914) Right Handle Cover Replacement, Remove the right handle cover: 3 단계, 이미지 3개 중 1개 Xbox Series X|S Controller (Model 1914) Right Handle Cover Replacement, Remove the right handle cover: 3 단계, 이미지 3개 중 2개 Xbox Series X|S Controller (Model 1914) Right Handle Cover Replacement, Remove the right handle cover: 3 단계, 이미지 3개 중 3개
    • The plastic clips on the outer edge make it difficult to slide along it and release the clips. Therefore, prying up on the inner edge is the easier option.
    • Pry up the middle inner edge of the handle cover with the opening tool to release the remaining clips.
    • Place a finger on top of the handle cover to prevent it from being forcefully ejected.
    • Remove the right handle cover.
    • To reinstall the right handle cover, position it on the back housing and press down firmly along the edges to engage all of the clips.
결론
Manuel Haeussermann
회원 가입일: 07/13/22
19,476 평판
안내서 71개를 작성함
iFixit iFixit 회원
Staff
118 회원들
안내서 19,474개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 24
지난 30일: 108
전체 시간: 1,469
