주요 콘텐츠로 건너뛰기
Xbox Series X|S Controller (Model 1914) Top Housing Replacement
Manuel Haeussermann
Manuel Haeussermann3 다른 기여자
최종 수정일 February 28, 2025
15 - 30 분
조정
Use this guide to replace the top housing on your Xbox Series X|S Controller (model 1914).
The top housing may need to be replaced if it's cracked, or you may be installing a new, customized one. The top housing is sometimes called a front panel, faceplate or top shell.
필요한 것
부품
도구
더보기...
  1. Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Remove the battery cover: 1 단계, 이미지 3개 중 1개 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Remove the battery cover: 1 단계, 이미지 3개 중 2개 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Remove the battery cover: 1 단계, 이미지 3개 중 3개
    • Use your fingers to slide up and remove the battery cover.
  2. Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Remove the batteries: 2 단계, 이미지 3개 중 1개 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Remove the batteries: 2 단계, 이미지 3개 중 2개 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Remove the batteries: 2 단계, 이미지 3개 중 3개
    • Remove the batteries.
    • When re-inserting the batteries, make sure to position them correctly, with their positive (+) and negative (–) ends matching up with the markings on the controller’s battery contacts. If your batteries are starting to corrode, replace them with new batteries.
  3. Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Insert an opening tool: 3 단계, 이미지 3개 중 1개 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Insert an opening tool: 3 단계, 이미지 3개 중 2개 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Insert an opening tool: 3 단계, 이미지 3개 중 3개
    • Insert an opening tool between the left handle cover and the bottom inner edge of the back housing.
  4. Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Release the left handle cover clips: 4 단계, 이미지 3개 중 1개 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Release the left handle cover clips: 4 단계, 이미지 3개 중 2개 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Release the left handle cover clips: 4 단계, 이미지 3개 중 3개
    • Strong plastic clips secure the handle cover. Significant force is required to release them.
    • Slide the opening tool along the inner edge of the left handle cover and pry intermittently to release the plastic clips.
  5. Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Remove the left handle cover: 5 단계, 이미지 3개 중 1개 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Remove the left handle cover: 5 단계, 이미지 3개 중 2개 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Remove the left handle cover: 5 단계, 이미지 3개 중 3개
    • The plastic clips on the outer edge make it difficult to slide along it and release the clips. Therefore, prying up on the inner edge is the easier option.
    • Pry up the middle inner edge of the handle cover with the opening tool to release the remaining clips.
    • Place a finger on top of the handle cover to prevent it from being forcefully ejected.
    • Remove the left handle cover.
    • To reinstall the left handle cover, position it on the back housing and press down firmly along the edges to engage all of the clips.
  6. Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Insert an opening tool: 6 단계, 이미지 3개 중 1개 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Insert an opening tool: 6 단계, 이미지 3개 중 2개 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Insert an opening tool: 6 단계, 이미지 3개 중 3개
    • Insert an opening tool between the right handle cover and the bottom inner edge of the back housing.
  7. Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Release the right handle cover clips: 7 단계, 이미지 3개 중 1개 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Release the right handle cover clips: 7 단계, 이미지 3개 중 2개 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Release the right handle cover clips: 7 단계, 이미지 3개 중 3개
    • Slide the opening tool along the inner edge of the right handle cover and pry intermittently to release the plastic clips.
  8. Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Remove the right handle cover: 8 단계, 이미지 3개 중 1개 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Remove the right handle cover: 8 단계, 이미지 3개 중 2개 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Remove the right handle cover: 8 단계, 이미지 3개 중 3개
    • Remove the right handle cover.
    • To reinstall the right handle cover, position it on the back housing and press down firmly along the edges to engage all of the clips.
  9. Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Reposition the battery compartment sticker: 9 단계, 이미지 2개 중 1개 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Reposition the battery compartment sticker: 9 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • The sticker in the battery compartment covers a housing screw. Peel it back or pierce through it with a screwdriver.
    • Use a pair of tweezers or your fingers to peel back the sticker to reveal the screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
  10. Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Unfasten the top housing: 10 단계, 이미지 2개 중 1개 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Unfasten the top housing: 10 단계, 이미지 2개 중 2개
    • Use a Torx T8 Security driver to remove the five 9.3 mm-long screws securing the top housing, three near the top and two at the bottom.
  11. Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Remove the top housing: 11 단계, 이미지 3개 중 1개 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Remove the top housing: 11 단계, 이미지 3개 중 2개 Xbox Series X|S Controller (Model 1914) Top Housing Replacement, Remove the top housing: 11 단계, 이미지 3개 중 3개
    • Lift the top housing straight up to remove it.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Manuel Haeussermann
회원 가입일: 07/13/22
19,496 평판
안내서 71개를 작성함
iFixit iFixit 회원
Staff
118 회원들
안내서 19,547개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 63
지난 30일: 347
전체 시간: 5,341
