주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xbox Series X (Digital Edition) Back Panel Replacement
필요한 것
  1. Xbox Series X (Digital Edition) Back Panel Replacement, Uncover the back panel screws: 1 단계, 이미지 2개 중 1개 Xbox Series X (Digital Edition) Back Panel Replacement, Uncover the back panel screws: 1 단계, 이미지 2개 중 2개
    • Before you begin, completely power down and unplug all cables from your console.
    • Two stickers cover the back panel screws. You can remove the stickers without heating them, though it makes them much easier to remove cleanly.
    • Heat an iOpener and lay it on the smaller sticker near the bottom of the back panel for two minutes.
    • Alternatively, you can use a hair dryer to heat the sticker.
    댓글 쓰기
  2. Xbox Series X (Digital Edition) Back Panel Replacement: 2 단계, 이미지 3개 중 1개 Xbox Series X (Digital Edition) Back Panel Replacement: 2 단계, 이미지 3개 중 2개 Xbox Series X (Digital Edition) Back Panel Replacement: 2 단계, 이미지 3개 중 3개
    • Use a pair of angled tweezers to remove the sticker hiding the first screw on the back panel, near the base.
    댓글 쓰기
  3. Xbox Series X (Digital Edition) Back Panel Replacement: 3 단계, 이미지 3개 중 1개 Xbox Series X (Digital Edition) Back Panel Replacement: 3 단계, 이미지 3개 중 2개 Xbox Series X (Digital Edition) Back Panel Replacement: 3 단계, 이미지 3개 중 3개
    • Use an iOpener or hair dryer to heat the larger sticker near the center of the back panel.
    댓글 쓰기
  4. Xbox Series X (Digital Edition) Back Panel Replacement: 4 단계, 이미지 3개 중 1개 Xbox Series X (Digital Edition) Back Panel Replacement: 4 단계, 이미지 3개 중 2개 Xbox Series X (Digital Edition) Back Panel Replacement: 4 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger to scrape up a corner of the larger sticker until you can grip it with a pair of blunt tweezers.
    • Use blunt tweezers to peel back the sticker to reveal the second screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
    • Technically, these are tamper-evident stickers, but don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
    댓글 쓰기
  5. Xbox Series X (Digital Edition) Back Panel Replacement, Remove the back panel screws: 5 단계, 이미지 2개 중 1개 Xbox Series X (Digital Edition) Back Panel Replacement, Remove the back panel screws: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
    • Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
    댓글 쓰기
  6. Xbox Series X (Digital Edition) Back Panel Replacement, Unclip the back panel: 6 단계, 이미지 3개 중 1개 Xbox Series X (Digital Edition) Back Panel Replacement, Unclip the back panel: 6 단계, 이미지 3개 중 2개 Xbox Series X (Digital Edition) Back Panel Replacement, Unclip the back panel: 6 단계, 이미지 3개 중 3개
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
    • Pry up the back panel to release it from the locking clips.
    댓글 쓰기
  7. Xbox Series X (Digital Edition) Back Panel Replacement: 7 단계, 이미지 3개 중 1개 Xbox Series X (Digital Edition) Back Panel Replacement: 7 단계, 이미지 3개 중 2개 Xbox Series X (Digital Edition) Back Panel Replacement: 7 단계, 이미지 3개 중 3개
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
    댓글 쓰기
  8. Xbox Series X (Digital Edition) Back Panel Replacement, Remove the back panel: 8 단계, 이미지 3개 중 1개 Xbox Series X (Digital Edition) Back Panel Replacement, Remove the back panel: 8 단계, 이미지 3개 중 2개 Xbox Series X (Digital Edition) Back Panel Replacement, Remove the back panel: 8 단계, 이미지 3개 중 3개
    • Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
    • During reassembly, press along the edges of the back panel to snap it into place.
    댓글 쓰기
  9. Xbox Series X (Digital Edition) Back Panel Replacement: 9 단계, 이미지 3개 중 1개 Xbox Series X (Digital Edition) Back Panel Replacement: 9 단계, 이미지 3개 중 2개 Xbox Series X (Digital Edition) Back Panel Replacement: 9 단계, 이미지 3개 중 3개
    • The back panel slots into a gap at the top of the shell.
    • Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
    • Remove the back panel.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Spencer Day
회원 가입일: 09/14/22
195,262 평판
안내서 1,243개를 작성함
iFixit iFixit 회원
Staff
122 회원들
안내서 26,617개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 19
지난 30일: 88
전체 시간: 966
