주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xbox Series X Fan Replacement
필요한 것
    1. Xbox Series X Fan Replacement, Uncover the back panel screws: 1 단계, 이미지 2개 중 1개 Xbox Series X Fan Replacement, Uncover the back panel screws: 1 단계, 이미지 2개 중 2개
      • Before you begin, completely power down and unplug all cables from your console.
      • Use a pair of tweezers to remove the sticker hiding the first screw on the back panel, near the base.
      댓글 쓰기
    2. Xbox Series X Fan Replacement: 2 단계, 이미지 3개 중 1개 Xbox Series X Fan Replacement: 2 단계, 이미지 3개 중 2개 Xbox Series X Fan Replacement: 2 단계, 이미지 3개 중 3개
      • For cleaner removal, use an iOpener or hair dryer to heat the sticker.
      • Use a pair of tweezers or a sharp blade to peel up a corner of the large sticker on the back panel. Use your fingers to peel it farther, just enough to reveal the second screw.
      • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
      • Technically, these are tamper-evident stickers, but don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
      댓글 쓰기
    3. Xbox Series X Fan Replacement, Remove the back panel screws: 3 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      Magnetic Project Mat
      $19.95
      • Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
      댓글 쓰기
    4. Xbox Series X Fan Replacement, Unclip the back panel: 4 단계, 이미지 3개 중 1개 Xbox Series X Fan Replacement, Unclip the back panel: 4 단계, 이미지 3개 중 2개 Xbox Series X Fan Replacement, Unclip the back panel: 4 단계, 이미지 3개 중 3개
      • Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
      • Pry up the back panel to release it from the locking clips.
      댓글 쓰기
    5. Xbox Series X Fan Replacement: 5 단계, 이미지 2개 중 1개 Xbox Series X Fan Replacement: 5 단계, 이미지 2개 중 2개
      • Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
      댓글 쓰기
    6. Xbox Series X Fan Replacement, Remove the back panel: 6 단계, 이미지 3개 중 1개 Xbox Series X Fan Replacement, Remove the back panel: 6 단계, 이미지 3개 중 2개 Xbox Series X Fan Replacement, Remove the back panel: 6 단계, 이미지 3개 중 3개
      • Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
      • During reassembly, press along the edges of the back panel to snap it into place.
      댓글 쓰기
    7. Xbox Series X Fan Replacement: 7 단계, 이미지 3개 중 1개 Xbox Series X Fan Replacement: 7 단계, 이미지 3개 중 2개 Xbox Series X Fan Replacement: 7 단계, 이미지 3개 중 3개
      • The back panel slots into a gap at the top of the shell.
      • Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
      • Remove the back panel.
      댓글 쓰기
    1. Xbox Series X Fan Replacement, Remove the fan screws: 8 단계, 이미지 1개 중 1개
      • Use a T8 Torx driver to remove the three screws securing the fan to the center chassis:
      • One 10.5 mm pancake screw
      • Two 8.8 mm screws
      댓글 쓰기
    2. Xbox Series X Fan Replacement, Disconnect the fan cable: 9 단계, 이미지 3개 중 1개 Xbox Series X Fan Replacement, Disconnect the fan cable: 9 단계, 이미지 3개 중 2개 Xbox Series X Fan Replacement, Disconnect the fan cable: 9 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Use your fingers or a pair of blunt tweezers to grip the edges of the fan cable connector, and pull up to disconnect it from the center chassis.
      • Always pull cables by their connectors and not the wires themselves.
      • During reassembly, route the fan cable underneath its small cable guide on the fan housing so it doesn't interfere with the back panel.
      댓글 쓰기
    3. Xbox Series X Fan Replacement, Remove the fan: 10 단계, 이미지 2개 중 1개 Xbox Series X Fan Replacement, Remove the fan: 10 단계, 이미지 2개 중 2개
      • Slide the fan out of its slot to remove it.
      • During reinstallation, note that the fan can only be installed one way—make sure Master Chief is facing you.
      • If you're replacing the fan, a new fan might not include the plastic installation bracket, which is attached to the fan with four T10 Torx screws. This isn't pictured in this guide.
      댓글 쓰기
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Xbox Series X Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 37명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Carsten Frauenheim
회원 가입일: 03/10/20
168,848 평판
안내서 437개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 72,939개를 작성함
1가이드 댓글
Thank you for the support! I picked up the "Essential Electronics" and it provided all i needed. Excellent tool kit!
Modesto Delvalle Jr - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 36
지난 7일: 308
지난 30일: 1,150
전체 시간: 65,033
