소개
Use this guide to replace a damaged or broken rear glass on your Xiaomi Redmi Note 8.
Before you begin this procedure, be sure to have a set of replacement adhesives for both the rear glass and the fingerprint reader.
필요한 것
Prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath.
Secure a suction handle to the bottom edge of the rear glass, as close to the edge as possible.
Lift the rear glass with the suction handle to create a small gap between the back cover and the frame.
Insert an opening pick into the gap you created.
Slide the opening pick to the bottom right corner to slice the adhesive.
Leave the opening pick in place to prevent the adhesive from resealing.
Insert a second opening pick at the bottom edge of your phone.
Slide the opening pick to the bottom left corner to slice the adhesive.
Leave the opening picks in place to prevent the adhesive from resealing.
Insert a third opening pick at the bottom left corner of your phone.
Slide the opening pick along the left edge of your phone to slice the adhesive.
Leave the opening pick in the top left corner to prevent the adhesive from resealing.
Carefully fold the rear glass to the right side of the phone assembly like you'd open the back cover of a book.
Use a spudger to disconnect the fingerprint reader by prying the connector straight up from its socket.
Remove the rear glass assembly.
Prepare an iOpener and apply it to the fingerprint reader on the rear glass assembly for at least one minute to loosen the adhesive underneath.
Slide an opening pick underneath the fingerprint reader.
Use the opening pick to slice the adhesive of the fingerprint reader and pry it up.
Use the opening pick to carefully loosen the fingerprint reader cable adhesive.
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before you install it.
다른 2명이 해당 안내서를 완성하였습니다.
