주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xiaomi Redmi Note 8 Screen Replacement
필요한 것
  1. Xiaomi Redmi Note 8 Screen Replacement, Heat the rear glass: 1 단계, 이미지 1개 중 1개
    • Prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    댓글 쓰기
  2. Xiaomi Redmi Note 8 Screen Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 1개 Xiaomi Redmi Note 8 Screen Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 2개 Xiaomi Redmi Note 8 Screen Replacement, Insert an opening pick: 2 단계, 이미지 3개 중 3개
    • Secure a suction handle to the bottom edge of the rear glass, as close to the edge as possible.
    • If the rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the rear glass with the suction handle to create a small gap between the back cover and the frame.
    • In case you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
    댓글 쓰기
  3. Xiaomi Redmi Note 8 Screen Replacement, Slice the adhesive: 3 단계, 이미지 2개 중 1개 Xiaomi Redmi Note 8 Screen Replacement, Slice the adhesive: 3 단계, 이미지 2개 중 2개
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
    댓글 쓰기
  4. Xiaomi Redmi Note 8 Screen Replacement, Slice the adhesive: 4 단계, 이미지 3개 중 1개 Xiaomi Redmi Note 8 Screen Replacement, Slice the adhesive: 4 단계, 이미지 3개 중 2개 Xiaomi Redmi Note 8 Screen Replacement, Slice the adhesive: 4 단계, 이미지 3개 중 3개
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for one to two minutes to reheat it.
    • Insert a third opening pick at the bottom left corner of your phone.
    • Slide the opening pick along the left edge of your phone to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
    댓글 쓰기
  5. Xiaomi Redmi Note 8 Screen Replacement: 5 단계, 이미지 2개 중 1개 Xiaomi Redmi Note 8 Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Insert a fourth opening pick underneath the top left corner of your phone.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
    댓글 쓰기
  6. Xiaomi Redmi Note 8 Screen Replacement: 6 단계, 이미지 2개 중 1개 Xiaomi Redmi Note 8 Screen Replacement: 6 단계, 이미지 2개 중 2개
    • Insert a fifth opening pick underneath the top right corner.
    • Slide the opening pick along the right edge of the rear glass to slice the remaining adhesive.
    • Don't try to remove the rear glass all the way yet. The camera cover and fingerprint assembly is still adhered to its back.
    댓글 쓰기
  7. Xiaomi Redmi Note 8 Screen Replacement, Open your phone: 7 단계, 이미지 3개 중 1개 Xiaomi Redmi Note 8 Screen Replacement, Open your phone: 7 단계, 이미지 3개 중 2개 Xiaomi Redmi Note 8 Screen Replacement, Open your phone: 7 단계, 이미지 3개 중 3개
    • Carefully fold the rear glass to the right side of the phone assembly like you'd open the back cover of a book.
    • Avoid straining the finger print cable during this procedure.
    댓글 쓰기
  8. Xiaomi Redmi Note 8 Screen Replacement, Disconnect the fingerprint reader: 8 단계, 이미지 3개 중 1개 Xiaomi Redmi Note 8 Screen Replacement, Disconnect the fingerprint reader: 8 단계, 이미지 3개 중 2개 Xiaomi Redmi Note 8 Screen Replacement, Disconnect the fingerprint reader: 8 단계, 이미지 3개 중 3개
    • Use a spudger to disconnect the fingerprint reader by prying the connector straight up from its socket.
    • Remove the rear glass assembly.
    댓글 쓰기
  9. Xiaomi Redmi Note 8 Screen Replacement, Unfasten the motherboard cover screws: 9 단계, 이미지 1개 중 1개
    • Use screwdriver to remove the eleven screws securing the motherboard cover:
    • Ten 3.9 mm-long Phillips screws
    • One 3.4 mm-long Phillips screw
    댓글 쓰기
  10. Xiaomi Redmi Note 8 Screen Replacement, Pry up the motherboard cover: 10 단계, 이미지 3개 중 1개 Xiaomi Redmi Note 8 Screen Replacement, Pry up the motherboard cover: 10 단계, 이미지 3개 중 2개 Xiaomi Redmi Note 8 Screen Replacement, Pry up the motherboard cover: 10 단계, 이미지 3개 중 3개
    • Insert the tip of an opening pick underneath the bottom left edge of the motherboard cover.
    • Do not insert the opening pick deeper than 3-4 mm to prevent damaging the motherboard.
    • Slide the opening pick along the left edge of the motherboard cover to unhinge the plastic clips and pry it up.
    댓글 쓰기
  11. Xiaomi Redmi Note 8 Screen Replacement: 11 단계, 이미지 2개 중 1개 Xiaomi Redmi Note 8 Screen Replacement: 11 단계, 이미지 2개 중 2개
    • Insert the tip of an opening pick underneath the bottom right edge of the motherboard cover.
    • Slide the opening pick along the right edge of the motherboard cover to unhinge the plastic clips and pry it up.
    댓글 쓰기
  12. Xiaomi Redmi Note 8 Screen Replacement, Remove the motherboard cover: 12 단계, 이미지 2개 중 1개 Xiaomi Redmi Note 8 Screen Replacement, Remove the motherboard cover: 12 단계, 이미지 2개 중 2개
    • Remove the motherboard cover.
    댓글 쓰기
  13. Xiaomi Redmi Note 8 Screen Replacement, Disconnect the battery: 13 단계, 이미지 2개 중 1개 Xiaomi Redmi Note 8 Screen Replacement, Disconnect the battery: 13 단계, 이미지 2개 중 2개
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
    댓글 쓰기
  14. Xiaomi Redmi Note 8 Screen Replacement, Disconnect the display flex cable: 14 단계, 이미지 2개 중 1개 Xiaomi Redmi Note 8 Screen Replacement, Disconnect the display flex cable: 14 단계, 이미지 2개 중 2개
    • Use a spudger to disconnect the display flex cable by prying the connector straight up from its socket.
    댓글 쓰기
  15. Xiaomi Redmi Note 8 Screen Replacement, Unfasten the daughterboard cover screws: 15 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the seven 3.9 mm-long screws securing the daughterboard cover.
    댓글 쓰기
  16. Xiaomi Redmi Note 8 Screen Replacement, Pry up the daughterboard cover: 16 단계, 이미지 2개 중 1개 Xiaomi Redmi Note 8 Screen Replacement, Pry up the daughterboard cover: 16 단계, 이미지 2개 중 2개
    • Slide the tip of an opening pick (about 3-4 mm) underneath the top right edge of the daughterboard cover.
    • Twist the opening pick sideways to pry up the daughterboard cover including the loudspeaker.
    댓글 쓰기
  17. Xiaomi Redmi Note 8 Screen Replacement, Remove the daughterboard cover: 17 단계, 이미지 2개 중 1개 Xiaomi Redmi Note 8 Screen Replacement, Remove the daughterboard cover: 17 단계, 이미지 2개 중 2개
    • Remove the daughterboard cover and loudspeaker assembly.
    댓글 쓰기
  18. Xiaomi Redmi Note 8 Screen Replacement, Loosen the display adhesive: 18 단계, 이미지 1개 중 1개
    • Apply a heated iOpener to the screen for at least two minutes or use a heat gun to soften the adhesive underneath.
    댓글 쓰기
  19. Xiaomi Redmi Note 8 Screen Replacement, Insert an opening pick: 19 단계, 이미지 3개 중 1개 Xiaomi Redmi Note 8 Screen Replacement, Insert an opening pick: 19 단계, 이미지 3개 중 2개 Xiaomi Redmi Note 8 Screen Replacement, Insert an opening pick: 19 단계, 이미지 3개 중 3개
    • Once the screen is warm to touch, apply a suction cup to the bottom edge of the phone.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the screen.
    • Lift the screen with the suction handle to create a small gap between the screen and the midframe.
    • Insert an opening pick in the gap between the midframe and the screen.
    • In case you only want to replace the display glass but not the LCD and digitizer you need to be especially carful during the next step. There's a small cable at the bottom right end of the LCD which is very fragile. Only slide with the very tip of your opening pick (about 1-2 mm).
    • Slide the opening pick to the bottom right corner of the screen to slice its adhesive. Leave the opening pick in place to prevent the adhesive from resealing.
    댓글 쓰기
  20. Xiaomi Redmi Note 8 Screen Replacement, Slice the adhesive: 20 단계, 이미지 2개 중 1개 Xiaomi Redmi Note 8 Screen Replacement, Slice the adhesive: 20 단계, 이미지 2개 중 2개
    • Insert a second opening pick and slide it to the bottom left corner of the screen to cut the adhesive.
    댓글 쓰기
  21. Xiaomi Redmi Note 8 Screen Replacement: 21 단계, 이미지 3개 중 1개 Xiaomi Redmi Note 8 Screen Replacement: 21 단계, 이미지 3개 중 2개 Xiaomi Redmi Note 8 Screen Replacement: 21 단계, 이미지 3개 중 3개
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener or heat gun for 1-2 minutes to reheat it.
    • Insert a third opening pick underneath the bottom left corner of the screen.
    • Slide the opening pick along the left edge of the screen to slice the adhesive. Leave it in the top left corner to prevent the adhesive from resealing.
    댓글 쓰기
  22. Xiaomi Redmi Note 8 Screen Replacement: 22 단계, 이미지 2개 중 1개 Xiaomi Redmi Note 8 Screen Replacement: 22 단계, 이미지 2개 중 2개
    • When you slice near the front facing camera, insert only the tip of the opening pick (about 3-4 mm) to avoid damaging or smearing the camera.
    • Insert a fourth opening pick at the top left corner of the screen.
    • Slide the opening pick along the top edge of the phone to slice the adhesive.
    • Leave the opening pick in the top right corner of the screen to prevent the adhesive from resealing.
    댓글 쓰기
  23. Xiaomi Redmi Note 8 Screen Replacement: 23 단계, 이미지 2개 중 1개 Xiaomi Redmi Note 8 Screen Replacement: 23 단계, 이미지 2개 중 2개
    • Insert a fifth opening pick and slide it along the right edge of the phone to slice the remaining adhesive.
    • Do not try to remove the display all the way yet, the display cable is still threaded through the frame.
    댓글 쓰기
  24. Xiaomi Redmi Note 8 Screen Replacement, Remove the screen: 24 단계, 이미지 3개 중 1개 Xiaomi Redmi Note 8 Screen Replacement, Remove the screen: 24 단계, 이미지 3개 중 2개 Xiaomi Redmi Note 8 Screen Replacement, Remove the screen: 24 단계, 이미지 3개 중 3개
    • Thread the display flex cable through the gap in the midframe and remove the screen.
    • Compare your new replacement part to the original part—you may need to transfer remaining components like the speaker grill from your old screen to your new screen.
    • Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
    • During reassembly, follow this guide in case you're using a pre-cut adhesive card.
    댓글 쓰기
결론
If possible, turn on your device and test your repair before installing new adhesive and resealing.
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the back of the screen.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 26명이 해당 안내서를 완성하였습니다.
Dominik Schnabelrauch
회원 가입일: 11/23/16
261,066 평판
안내서 682개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 28,236개를 작성함
4가이드 댓글
Muy buena guía
Jesus Castrillo - 답글 공유
Gracias Jesús por el comentario!
Mariana Roca - 답글 공유
спасибо вам за вкусный и полезный материал.)
Jony Dopa - 답글 공유
My phone is open but not clicking anywhere power button also get out
Radhika - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 55
지난 30일: 268
전체 시간: 17,137
