소개
Use this guide to replace a damaged back cover on your Xiaomi Redmi Note 9.
In case your replacement part doesn't come with a new NFC antenna, you're required to transfer the old antenna to your new back cover in order to maintain NFC functionality. If this is the case use this guide instead.
Before you begin this procedure, be sure to have a set of replacement adhesives for both the back cover and the fingerprint reader.
필요한 것
Insert a SIM card eject tool, a SIM eject bit, or a straightened paper clip into the hole on the SIM tray located at the left edge of the phone.
Press directly into the hole to eject the SIM card tray.
Remove the SIM card tray.
Prepare an iOpener and apply it to the back cover for at least two minutes to loosen the adhesive underneath.
Secure a suction handle to the bottom edge of the screen, as close to the edge as possible.
Lift the screen and phone assembly with the suction handle to create a small gap between the assembly and the back cover.
Insert an opening pick in a steep angle into the gap you created. This might require some force.
Slide the opening pick to the bottom right corner to slice the adhesive and release the plastic clips holding the back cover in place.
Insert a second opening pick in a steep angle at the bottom edge of your phone.
Slide the opening pick to the bottom left corner to release the plastic clips and to slice the adhesive.
Leave the opening picks in place to prevent the adhesive from resealing.
Slide the bottom left opening pick along the left edge of your phone to release the plastic clips and slice the adhesive.
Leave the opening pick in the top left corner to prevent the adhesive from resealing.
Prepare an iOpener and apply it to the back cover where the fingerprint reader is located for at least two minutes to loosen the adhesive underneath.
Carefully lift the back cover upwards whilst pressing down the fingerprint reader with a finger.
Remove the back cover.
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before you install it.
다른 2명이 해당 안내서를 완성하였습니다.
