주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Zerodate T26 USB-C Port Replacement
필요한 것
    1. Zerodate T26 USB-C Port Replacement, Scroll Wheel: 1 단계, 이미지 2개 중 1개 Zerodate T26 USB-C Port Replacement, Scroll Wheel: 1 단계, 이미지 2개 중 2개
      • Remove the top shell of the mouse by using the iFixit opening tool to carefully pry the top shell apart from the bottom plate.
      댓글 쓰기
    2. Zerodate T26 USB-C Port Replacement: 2 단계, 이미지 2개 중 1개 Zerodate T26 USB-C Port Replacement: 2 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Remove the adhesive pads using precision tweezers or the iFixit opening tool.
      • Adhesive pads are located on the bottom of the mouse.
      댓글 쓰기
    3. Zerodate T26 USB-C Port Replacement: 3 단계, 이미지 2개 중 1개 Zerodate T26 USB-C Port Replacement: 3 단계, 이미지 2개 중 2개
      • Use a Phillips #00 screwdriver to remove all four 10 mm screws.
      댓글 쓰기
    4. Zerodate T26 USB-C Port Replacement: 4 단계, 이미지 2개 중 1개 Zerodate T26 USB-C Port Replacement: 4 단계, 이미지 2개 중 2개
      • Carefully pull the middle shell apart from the bottom plate.
      • The circuit board should then be visible and attached to the bottom plate.
      댓글 쓰기
    5. Zerodate T26 USB-C Port Replacement: 5 단계, 이미지 2개 중 1개 Zerodate T26 USB-C Port Replacement: 5 단계, 이미지 2개 중 2개
      • Remove the scroll wheel by pushing it to the right and pulling up.
      댓글 쓰기
    1. Zerodate T26 USB-C Port Replacement, USB-C Port: 6 단계, 이미지 3개 중 1개 Zerodate T26 USB-C Port Replacement, USB-C Port: 6 단계, 이미지 3개 중 2개 Zerodate T26 USB-C Port Replacement, USB-C Port: 6 단계, 이미지 3개 중 3개
      • Take out the battery obstructing movement. This should now allow you to gently pull the circuit board up from the bottom of the mouse.
      • Please be very careful when pulling up the circuit board! Yanking it out could result in further damage to the mouse. Make sure you go slow and steady!
      댓글 쓰기
    2. Zerodate T26 USB-C Port Replacement: 7 단계, 이미지 1개 중 1개
      • De-solder the charging port at one end of the mouse, in order to carefully remove it for a replacement.
      • Please be sure to review safety guidelines and guided steps on soldering before attempting to remove any circuitry. In order to keep yourself safe and your mouse undamaged, please follow the guide found here to learn to properly solder.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Janice Rullan
회원 가입일: 03/13/23
662 평판
안내서 6개를 작성함
UMass Dartmouth, Team 2-3, Petersen Spring 2023 UMass Dartmouth, Team 2-3, Petersen Spring 2023 회원
UMASSD-PETERSEN-S23S2G3
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 29
전체 시간: 432
