주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Zoom H1 Handy Recorder Line-In Port Replacement
필요한 것
    1. Zoom H1 Handy Recorder Line-In Port Replacement, Line-In Port: 1 단계, 이미지 1개 중 1개
      • Flip device over so the display is facing down.
      댓글 쓰기
    2. Zoom H1 Handy Recorder Line-In Port Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the battery cover by pressing down on battery cover and sliding it to the right.
      댓글 쓰기
    3. Zoom H1 Handy Recorder Line-In Port Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the two 10 mm Phillips #00 screws located below the microphones on the back cover.
      댓글 쓰기
    4. Zoom H1 Handy Recorder Line-In Port Replacement: 4 단계, 이미지 1개 중 1개
      • Remove the back cover (using a plastic removal tool around the edges if needed).
      댓글 쓰기
    5. Zoom H1 Handy Recorder Line-In Port Replacement: 5 단계, 이미지 1개 중 1개
      • De-solder and remove the heat shield.
      • Be careful while removing this shield, since the copper sheet is very easy to rip.
      댓글 쓰기
    6. Zoom H1 Handy Recorder Line-In Port Replacement: 6 단계, 이미지 1개 중 1개
      • De-solder the line in port from its soldering points.
      • These points are located beneath the black shielding on the left side of the blue circuit board.
      댓글 쓰기
    7. Zoom H1 Handy Recorder Line-In Port Replacement: 7 단계, 이미지 1개 중 1개
      • Replace Line-in port and re-solder at points specified in Step 6.
      댓글 쓰기
    8. Zoom H1 Handy Recorder Line-In Port Replacement: 8 단계, 이미지 1개 중 1개
      • Reattach and re-solder the heat shielding back into place.
      • Again, be careful when soldering as it is very easy to melt through the heat shield and copper sheet beneath.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Alex
회원 가입일: 10/28/13
809 평판
안내서 5개를 작성함
3가이드 댓글
Do you know what and where I can get the replacement part at all…?
phily2k1clegg - 답글 공유
There are actually three fixing screws which must be unscrewed before the back can be removed, the third one is under the serial number label.
To actually change the audio socket the top PCB with the sockets has to be removed from the unit, it has the microphones soldered to the top edge and the speaker soldered to the bottom with short, delicate wires, it can be pulled out to one side without de-soldering anything by pulling the right (looking from the back) microphone off it’s supporting lug.
The top board is connected to the bottom board by a miniature plug and socket attached to both boards which can just be pulled apart.
sdsl - 답글 공유
Hello. My zoom h1 had fallen to the carpet. And the usb dc 5v usb socket had started to move and it is not doing its job. It is not working when i want to use the electric cable. Is fixing possible myself or another person?
cankarkin - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 17
지난 30일: 53
전체 시간: 5,334
