주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
bObi Pet Screen Replacement
필요한 것
    1. bObi Pet Screen  Replacement, Turn bObi Pet Off: 1 단계, 이미지 3개 중 1개 bObi Pet Screen  Replacement, Turn bObi Pet Off: 1 단계, 이미지 3개 중 2개 bObi Pet Screen  Replacement, Turn bObi Pet Off: 1 단계, 이미지 3개 중 3개
      • Before we get started, turn bObi Pet OFF and flip her over onto a flat surface.
      • Next, remove bObi Pet's dustbin. Grip the small tab on the back of the bin, and pull to remove.
      댓글 쓰기
    2. bObi Pet Screen  Replacement, Remove the Front Wheel: 2 단계, 이미지 2개 중 1개 bObi Pet Screen  Replacement, Remove the Front Wheel: 2 단계, 이미지 2개 중 2개
      • Grip the front wheel and pull straight up, using the screwdriver for leverage.
      • The wheel will pop out and you will see two screws beneath it.
      • There is a larger screw set deeper in the wheel compartment. Use the screwdriver to remove it.
      • Remember to keep all screws and parts removed from bObi Pet safely aside during the repair. They may be needed for re-assembly.
      댓글 쓰기
    3. bObi Pet Screen  Replacement, Remove the Dustbin's Holders: 3 단계, 이미지 3개 중 1개 bObi Pet Screen  Replacement, Remove the Dustbin's Holders: 3 단계, 이미지 3개 중 2개 bObi Pet Screen  Replacement, Remove the Dustbin's Holders: 3 단계, 이미지 3개 중 3개
      • Remove the screws on both sides of bObi Pet’s dustbin. Then, remove the corner pieces that were held down by the screws.
      • Grip the brush compartment and pull down to reveal two screws on a red fastener.
      • Remove them with the screwdriver.
      댓글 쓰기
    4. bObi Pet Screen  Replacement, Remove the Main Brush Attachment: 4 단계, 이미지 3개 중 1개 bObi Pet Screen  Replacement, Remove the Main Brush Attachment: 4 단계, 이미지 3개 중 2개 bObi Pet Screen  Replacement, Remove the Main Brush Attachment: 4 단계, 이미지 3개 중 3개
      • Pull the brush compartment up until the fastener is freed from bObi Pet. Then, detach the brush compartment's circuit plug and set it aside.
      • Remove the 4 screws located beneath the brush compartment.
      댓글 쓰기
    5. bObi Pet Screen  Replacement, Remove the Cover Screws: 5 단계, 이미지 2개 중 1개 bObi Pet Screen  Replacement, Remove the Cover Screws: 5 단계, 이미지 2개 중 2개
      • Remove the 2 screws on the dustbin’s red fastener.
      • Remove the fastener and set it aside for reassembly.
      • The cover is no longer secured, so carefully flip bObi Pet onto her wheels.
      댓글 쓰기
    6. bObi Pet Screen  Replacement, Detach the Cover: 6 단계, 이미지 3개 중 1개 bObi Pet Screen  Replacement, Detach the Cover: 6 단계, 이미지 3개 중 2개 bObi Pet Screen  Replacement, Detach the Cover: 6 단계, 이미지 3개 중 3개
      • Lift the cover to reveal the main board underneath.
      • Remove the two circuit plugs connecting the lid to the mainboard.
      • bObi Pet's cover is entirely separated, and you may now access any of her internal parts for replacement.
      댓글 쓰기
    1. bObi Pet Screen  Replacement, Remove the Screen: 7 단계, 이미지 3개 중 1개 bObi Pet Screen  Replacement, Remove the Screen: 7 단계, 이미지 3개 중 2개 bObi Pet Screen  Replacement, Remove the Screen: 7 단계, 이미지 3개 중 3개
      • Remove the four screws holding bObi Pet's screen.
      • Then, lift it straight up and out to make space for the replacement.
      댓글 쓰기
    2. bObi Pet Screen  Replacement, Place the New Screen: 8 단계, 이미지 3개 중 1개 bObi Pet Screen  Replacement, Place the New Screen: 8 단계, 이미지 3개 중 2개 bObi Pet Screen  Replacement, Place the New Screen: 8 단계, 이미지 3개 중 3개
      • Lay the new screen in the open space on bObi Pet's lid.
      • Align the screw holes on the screen with the screw posts in bObi Pet and push down until it lies flat.
      • Install all four screws, and you'll be ready to close bObi Pet. See the following instructions: Assemble bObi Pet Post-Repair
      댓글 쓰기
결론
To reassemble bObi Pet, see this tutorial: Assemble bObi Pet Post-Repair
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Chelsea
회원 가입일: 09/24/14
2,278 평판
안내서 31개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 24
전체 시간: 286
