주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iFit Act Battery Replacement
필요한 것
    1. iFit Act Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Hold the iFit band in both hands, with your thumbs on either side of the tracker pod at the center of the wristband.
      댓글 쓰기
    2. iFit Act Battery Replacement: 2 단계, 이미지 1개 중 1개
      • Using your index finger, gently push the tracker pod out of the wristband. It may help to do this over a table or other surface so the tracker pod doesn’t fall on the floor and break.
      댓글 쓰기
    3. iFit Act Battery Replacement: 3 단계, 이미지 1개 중 1개
      • Once the tracker pod is freed from the wristband, remove the back of the tracker pod using the plastic opening tool. The tool’s curved edge should be pointed toward the back of the device to avoid scratching the front display.
      댓글 쓰기
    4. iFit Act Battery Replacement: 4 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Using the curved metal precision tweezers, gently lift the battery out of the tracker pod.
      댓글 쓰기
    5. iFit Act Battery Replacement: 5 단계, 이미지 1개 중 1개
      • Place the new battery in the tracker pod. Make sure the positive side of the battery is face down in the cavity of the tracker pod.
      댓글 쓰기
    6. iFit Act Battery Replacement: 6 단계, 이미지 1개 중 1개
      • To close the tracker pod, place the top and bottom pieces between fingers as shown and snap them together.
      댓글 쓰기
결론
To assemble this device, follow these instructions in reverse order.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Charlotte Asmuth
회원 가입일: 09/28/15
104 평판
안내서 1개를 작성함
2가이드 댓글
The directions state that battery CR2032 is the battery for the ifit.act. I purchased this battery and it does not fit. Where can I get the battery that is compatible with ifit.act?
Revice Fisher - 답글 공유
The original battery should have identifying markings on the top so you can purchase an identical replacement. A standard CR 2032 coin cell battery is what’s specified by the manufacturer.
Jeff Suovanen - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 49
전체 시간: 16,397
