주요 콘텐츠로 건너뛰기
iMac G4 17 800 MHz EMC 1936 Battery Replacement
필요한 것
  1. iMac G4 17 800 MHz EMC 1936 Battery Replacement, Battery: 1 단계, 이미지 1/3 iMac G4 17 800 MHz EMC 1936 Battery Replacement, Battery: 1 단계, 이미지 2/3 iMac G4 17 800 MHz EMC 1936 Battery Replacement, Battery: 1 단계, 이미지 3/3
    • G4 bottom Plate with four captive Phillips screws
    • The bottom of the plate will list the serial number, MHz of the machine, standard RAM and hard drive size
  2. iMac G4 17 800 MHz EMC 1936 Battery Replacement: 2 단계, 이미지 1/1
    • Here the plate has been removed exposing the slot for the Airport Card and User added RAM slot.
  3. iMac G4 17 800 MHz EMC 1936 Battery Replacement: 3 단계, 이미지 1/2 iMac G4 17 800 MHz EMC 1936 Battery Replacement: 3 단계, 이미지 2/2
    • Remove the four T15 torx screws.
    • Set the unit on it's base, grasp the neck and tilt it to separate the base.
  4. iMac G4 17 800 MHz EMC 1936 Battery Replacement: 4 단계, 이미지 1/2 iMac G4 17 800 MHz EMC 1936 Battery Replacement: 4 단계, 이미지 2/2
    • The IDE cable unplugs first.
    • Locate the 3.6 volt 1/2 AA Lithium PRAM battery on the logic board and replace it.
결론
다른 10명이 해당 안내서를 완성하였습니다.
mayer
회원 가입일: 01/04/10
678,664 평판
안내서 12개 작성하였습니다
MacHale Enterprises MacHale Enterprises 회원
Business
1 회원
안내서 17개 작성하였습니다
2 Comments
These directions do not explain how to do any step of the process particularly showing where the battery is and how to carefully remove the bottom plate without breaking the logic board connector or cables. Also they are redundant as there are already directions to replace the PRAM Battery on this site. There is no point in there being two sets of directions for the same fix.
Sheldon Buchler - 답글
Sad that none of the pictures actually show the battery! Look for the other iMac G4 battery guide its better, although it misses the step of recoating the heat sinks with thermal paste.
Netmammal - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 25
전체 시간: 14,908
