주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iMac G5 17" Model A1058 Modem Replacement
필요한 것
    1. iMac G5 17" Model A1058 Modem Replacement, Rear Panel: 1 단계, 이미지 1개 중 1개
      • Lay the iMac display-side down on a flat surface.
      • Loosen the three Phillips screws securing the rear panel to the iMac.
      • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
      댓글 쓰기
    2. iMac G5 17" Model A1058 Modem Replacement: 2 단계, 이미지 3개 중 1개 iMac G5 17" Model A1058 Modem Replacement: 2 단계, 이미지 3개 중 2개 iMac G5 17" Model A1058 Modem Replacement: 2 단계, 이미지 3개 중 3개
      • Lift the rear panel slightly from the bottom edge of the iMac.
      • Pull the rear panel toward yourself and remove it from the iMac.
      댓글 쓰기
    1. iMac G5 17" Model A1058 Modem Replacement, AirPort Extreme: 3 단계, 이미지 1개 중 1개
      • Lift the AirPort card slightly by its plastic tab and pull it straight away from its socket.
      • During reinstallation, insert the AirPort card such that the antenna side is nearest the center of the logic board.
      댓글 쓰기
    2. iMac G5 17" Model A1058 Modem Replacement: 4 단계, 이미지 1개 중 1개
      • Insert the flat end of a spudger between the body of the AirPort card and its antenna connector.
      • Push the spudger away from the AirPort card to disconnect the AirPort antenna.
      • When reassembling your iMac, be sure to insert the AirPort card the way it was before disassembly.
      댓글 쓰기
    1. iMac G5 17" Model A1058 Modem Replacement, Modem: 5 단계, 이미지 1개 중 1개
      • Remove the two 5.5 mm T6 Torx screws securing the AirPort bracket to the logic board.
      • Slightly lift the AirPort bracket off the logic board.
      댓글 쓰기
    2. iMac G5 17" Model A1058 Modem Replacement: 6 단계, 이미지 1개 중 1개
      • De-route the AirPort antenna through the slot in the AirPort bracket.
      • Set the AirPort bracket aside.
      댓글 쓰기
    3. iMac G5 17" Model A1058 Modem Replacement: 7 단계, 이미지 2개 중 1개 iMac G5 17" Model A1058 Modem Replacement: 7 단계, 이미지 2개 중 2개
      • Remove the two 5.5 mm T6 Torx screws securing the modem to the logic board.
      • Pry the modem straight up from its top edge to disconnect it from the logic board.
      댓글 쓰기
    4. iMac G5 17" Model A1058 Modem Replacement: 8 단계, 이미지 1개 중 1개
      • Pull the modem cable connector straight away from the modem.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Walter Galan
710,623 평판
안내서 1,203개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 39
전체 시간: 6,266
