주요 콘텐츠로 건너뛰기
iMac G5 17" Model A1144 Camera Board Replacement
Andrew Bookholt
Andrew Bookholt2 다른 기여자
최종 수정일 July 31, 2013
예상시간 없음
조정
iSight not working? Replace your camera board.
필요한 것
도구
더보기...
  1. iMac G5 17" Model A1144 Camera Board Replacement, Access Door: 1 단계, 이미지 1개 중 1개
    • Before you work on the computer, unplug the computer and press the power button for 20-30 seconds to drain the stored energy in the power supply.
    • Loosen the two Phillips screws securing the access door to your iMac.
    • These screws are captive in the access door.
  2. iMac G5 17" Model A1144 Camera Board Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the access door from your iMac.
  3. iMac G5 17" Model A1144 Camera Board Replacement, Front Bezel: 3 단계, 이미지 1개 중 1개
    • Remove the three T8 Torx screws securing the front bezel to the rear panel.
  4. iMac G5 17" Model A1144 Camera Board Replacement: 4 단계, 이미지 2개 중 1개 iMac G5 17" Model A1144 Camera Board Replacement: 4 단계, 이미지 2개 중 2개
    • Orient the iMac face-up, on its backside.
    • Use your thumbs to press both RAM arms in past the front bezel for enough clearance to lift it off the rear case.
  5. iMac G5 17" Model A1144 Camera Board Replacement: 5 단계, 이미지 1개 중 1개
    • While holding the RAM arms in with your thumbs, lift the lower edge of the front bezel enough to clear the rear case.
  6. iMac G5 17" Model A1144 Camera Board Replacement: 6 단계, 이미지 3개 중 1개 iMac G5 17" Model A1144 Camera Board Replacement: 6 단계, 이미지 3개 중 2개 iMac G5 17" Model A1144 Camera Board Replacement: 6 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    • Re-orient your iMac so it sits upright on the stand.
    • Insert a plastic card up into the corner of the air vent slot at the top of the rear case.
    • Push the card toward the top of the iMac to release the front bezel latch.
    • Pull the front bezel away from the rear case.
    • Repeat this process for the other side of the front bezel.
    • It may be necessary to apply several layers of duct tape to the top of the access card to aid in releasing the latches.
    • If the bezel refuses to release, try pressing the lower edge back onto the rear case and repeat this opening process.
  7. iMac G5 17" Model A1144 Camera Board Replacement: 7 단계, 이미지 1개 중 1개
    • Lay your iMac stand-side down on a table.
    • Lift the front bezel from its lower edge and rotate it away from the rest of your iMac, minding the RAM arms that may get caught.
    • Lay the front bezel above the rest of the iMac.
  8. iMac G5 17" Model A1144 Camera Board Replacement: 8 단계, 이미지 1개 중 1개
    • If necessary, remove the piece of kapton tape wrapped around the microphone and camera cables.
  9. iMac G5 17" Model A1144 Camera Board Replacement: 9 단계, 이미지 2개 중 1개 iMac G5 17" Model A1144 Camera Board Replacement: 9 단계, 이미지 2개 중 2개
    • Disconnect both the camera and microphone cables.
  10. iMac G5 17" Model A1144 Camera Board Replacement, Camera Board: 10 단계, 이미지 1개 중 1개
    • Lay the bezel front side down on a table.
    • If necessary, peel back the tape covering the camera board.
  11. iMac G5 17" Model A1144 Camera Board Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the two T6 Torx screws securing the camera board to the front bezel.
  12. iMac G5 17" Model A1144 Camera Board Replacement: 12 단계, 이미지 1개 중 1개
    • Lift the camera board out from the front bezel.
결론
작성자
2다른 기여자 명과 함께
Andrew Bookholt
592,006 평판
안내서 619개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 6
전체 시간: 4,990
