주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iMac G5 17" Model A1144 Optical Drive Replacement
단지 전제 조건
이 가이드는 전제 조건만을 다룹니다! 이 가이드는 다른 절차의 일부이며 단독으로 사용할 수 없습니다.
필요한 것
    1. iMac G5 17" Model A1144 Optical Drive Replacement, Optical Drive: 1 단계, 이미지 2개 중 1개 iMac G5 17" Model A1144 Optical Drive Replacement, Optical Drive: 1 단계, 이미지 2개 중 2개
      • Remove the T10 Torx screw securing the optical drive flex cable mounting bracket to the logic board.
      • Remove the flex cable mounting bracket.
      댓글 쓰기
    2. iMac G5 17" Model A1144 Optical Drive Replacement: 2 단계, 이미지 1개 중 1개
      • Lift the optical drive flex cable connector straight up off the logic board.
      • This ribbon cable is thin and easily torn. Use caution.
      댓글 쓰기
    3. iMac G5 17" Model A1144 Optical Drive Replacement: 3 단계, 이미지 1개 중 1개
      • Move the SATA data cable away from the edge of the optical drive.
      댓글 쓰기
    4. iMac G5 17" Model A1144 Optical Drive Replacement: 4 단계, 이미지 1개 중 1개
      • Disconnect the optical drive thermal sensor.
      댓글 쓰기
    5. iMac G5 17" Model A1144 Optical Drive Replacement: 5 단계, 이미지 2개 중 1개 iMac G5 17" Model A1144 Optical Drive Replacement: 5 단계, 이미지 2개 중 2개
      • Apple's "engineers" didn't learn much about deflection and material stiffness when they went to "college", so this optical drive is particularly difficult to remove because the bracket flexes too much. The next few steps require some patience and a good amount of force.
      • Insert the flat end of a spudger into the gap between the optical drive and its bracket until it contacts the chassis.
      • Grab the spudger as close to the surface of the optical drive as you can, then depress the release tab with your thumb while pulling toward yourself.
      • The wedge shape of the spudger may cause it to slip out of the gap toward yourself. Be sure to press the spudger in toward the rear case while squeezing the release tab.
      댓글 쓰기
    6. iMac G5 17" Model A1144 Optical Drive Replacement: 6 단계, 이미지 1개 중 1개
      • Remove the two T10 Torx screws from the side of the optical drive.
      • It's a good idea to lay your iMac flat on a table before removing these screws to avoid them falling behind the logic board.
      댓글 쓰기
    7. iMac G5 17" Model A1144 Optical Drive Replacement: 7 단계, 이미지 1개 중 1개
      • Use the flat end of a spudger to press the bottom edge of the lower optical drive bracket release tab toward the lower edge of the iMac.
      • The optical drive should now be free from the rear case.
      • Maneuver the optical drive out of the rear case, minding the two plastic pins molded into the rear case near the open end of the optical drive that can break off.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Walter Galan
710,600 평판
안내서 1,203개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 37
전체 시간: 2,683
