주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iMac G5 17" Model A1144 Optical Drive Replacement
필요한 것
    1. iMac G5 17" Model A1144 Optical Drive Replacement, Access Door: 1 단계, 이미지 1개 중 1개
      • Before you work on the computer, unplug the computer and press the power button for 20-30 seconds to drain the stored energy in the power supply.
      • Loosen the two Phillips screws securing the access door to your iMac.
      • These screws are captive in the access door.
      댓글 쓰기
    2. iMac G5 17" Model A1144 Optical Drive Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the access door from your iMac.
      댓글 쓰기
    1. iMac G5 17" Model A1144 Optical Drive Replacement, Front Bezel: 3 단계, 이미지 1개 중 1개
      • Remove the three T8 Torx screws securing the front bezel to the rear panel.
      댓글 쓰기
    2. iMac G5 17" Model A1144 Optical Drive Replacement: 4 단계, 이미지 2개 중 1개 iMac G5 17" Model A1144 Optical Drive Replacement: 4 단계, 이미지 2개 중 2개
      • Orient the iMac face-up, on its backside.
      • Use your thumbs to press both RAM arms in past the front bezel for enough clearance to lift it off the rear case.
      댓글 쓰기
    3. iMac G5 17" Model A1144 Optical Drive Replacement: 5 단계, 이미지 1개 중 1개
      • While holding the RAM arms in with your thumbs, lift the lower edge of the front bezel enough to clear the rear case.
      댓글 쓰기
    4. iMac G5 17" Model A1144 Optical Drive Replacement: 6 단계, 이미지 3개 중 1개 iMac G5 17" Model A1144 Optical Drive Replacement: 6 단계, 이미지 3개 중 2개 iMac G5 17" Model A1144 Optical Drive Replacement: 6 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      Plastic Cards
      $2.99
      • Re-orient your iMac so it sits upright on the stand.
      • Insert a plastic card up into the corner of the air vent slot at the top of the rear case.
      • Push the card toward the top of the iMac to release the front bezel latch.
      • Pull the front bezel away from the rear case.
      • Repeat this process for the other side of the front bezel.
      • It may be necessary to apply several layers of duct tape to the top of the access card to aid in releasing the latches.
      • If the bezel refuses to release, try pressing the lower edge back onto the rear case and repeat this opening process.
      댓글 쓰기
    5. iMac G5 17" Model A1144 Optical Drive Replacement: 7 단계, 이미지 1개 중 1개
      • Lay your iMac stand-side down on a table.
      • Lift the front bezel from its lower edge and rotate it away from the rest of your iMac, minding the RAM arms that may get caught.
      • Lay the front bezel above the rest of the iMac.
      댓글 쓰기
    6. iMac G5 17" Model A1144 Optical Drive Replacement: 8 단계, 이미지 1개 중 1개
      • If necessary, remove the piece of kapton tape wrapped around the microphone and camera cables.
      댓글 쓰기
    7. iMac G5 17" Model A1144 Optical Drive Replacement: 9 단계, 이미지 2개 중 1개 iMac G5 17" Model A1144 Optical Drive Replacement: 9 단계, 이미지 2개 중 2개
      • Disconnect both the camera and microphone cables.
      댓글 쓰기
    1. iMac G5 17" Model A1144 Optical Drive Replacement, Display: 10 단계, 이미지 1개 중 1개
      • Peel back the aluminum EMI shield up off the lower three edges of the rear case.
      • It is not necessary to peel the EMI shield off the display.
      • We found it helpful to tape the EMI shield up against the display to keep it out of the way.
      댓글 쓰기
    2. iMac G5 17" Model A1144 Optical Drive Replacement: 11 단계, 이미지 2개 중 1개 iMac G5 17" Model A1144 Optical Drive Replacement: 11 단계, 이미지 2개 중 2개
      • Remove the two 5 mm T6 Torx screws securing the display data cable to the logic board.
      • Using its attached black tab, pull the display data cable connector up off the logic board.
      댓글 쓰기
    3. iMac G5 17" Model A1144 Optical Drive Replacement: 12 단계, 이미지 1개 중 1개
      • Pull the inverter cable connector up off its socket on the logic board.
      댓글 쓰기
    4. iMac G5 17" Model A1144 Optical Drive Replacement: 13 단계, 이미지 1개 중 1개
      • Peel back the aluminum EMI tape from the two vertical edges of the display.
      • During reassembly, it is helpful to use several small strips of tape to hold the EMI shielding along the left and right edges of the display footprint out of the way before lowering the display into the rear case of your iMac.
      댓글 쓰기
    5. iMac G5 17" Model A1144 Optical Drive Replacement: 14 단계, 이미지 2개 중 1개 iMac G5 17" Model A1144 Optical Drive Replacement: 14 단계, 이미지 2개 중 2개
      • Remove the four recessed coarse-thread 7.5 mm T10 Torx screws securing the display to the rear case.
      • These screws are recessed, so a thin screwdriver such as this is essential for removal. Bit drivers tend to be too short for this application.
      댓글 쓰기
    6. iMac G5 17" Model A1144 Optical Drive Replacement: 15 단계, 이미지 1개 중 1개
      • Lift the display from its lower edge and pull it toward yourself to peel it off the EMI shield attached to its top edge.
      • Be mindful of any cables that may get caught during removal.
      댓글 쓰기
    1. iMac G5 17" Model A1144 Optical Drive Replacement, Optical Drive: 16 단계, 이미지 2개 중 1개 iMac G5 17" Model A1144 Optical Drive Replacement, Optical Drive: 16 단계, 이미지 2개 중 2개
      • Remove the T10 Torx screw securing the optical drive flex cable mounting bracket to the logic board.
      • Remove the flex cable mounting bracket.
      댓글 쓰기
    2. iMac G5 17" Model A1144 Optical Drive Replacement: 17 단계, 이미지 1개 중 1개
      • Lift the optical drive flex cable connector straight up off the logic board.
      • This ribbon cable is thin and easily torn. Use caution.
      댓글 쓰기
    3. iMac G5 17" Model A1144 Optical Drive Replacement: 18 단계, 이미지 1개 중 1개
      • Move the SATA data cable away from the edge of the optical drive.
      댓글 쓰기
    4. iMac G5 17" Model A1144 Optical Drive Replacement: 19 단계, 이미지 1개 중 1개
      • Disconnect the optical drive thermal sensor.
      댓글 쓰기
    5. iMac G5 17" Model A1144 Optical Drive Replacement: 20 단계, 이미지 2개 중 1개 iMac G5 17" Model A1144 Optical Drive Replacement: 20 단계, 이미지 2개 중 2개
      • Apple's "engineers" didn't learn much about deflection and material stiffness when they went to "college", so this optical drive is particularly difficult to remove because the bracket flexes too much. The next few steps require some patience and a good amount of force.
      • Insert the flat end of a spudger into the gap between the optical drive and its bracket until it contacts the chassis.
      • Grab the spudger as close to the surface of the optical drive as you can, then depress the release tab with your thumb while pulling toward yourself.
      • The wedge shape of the spudger may cause it to slip out of the gap toward yourself. Be sure to press the spudger in toward the rear case while squeezing the release tab.
      댓글 쓰기
    6. iMac G5 17" Model A1144 Optical Drive Replacement: 21 단계, 이미지 1개 중 1개
      • Remove the two T10 Torx screws from the side of the optical drive.
      • It's a good idea to lay your iMac flat on a table before removing these screws to avoid them falling behind the logic board.
      댓글 쓰기
    7. iMac G5 17" Model A1144 Optical Drive Replacement: 22 단계, 이미지 1개 중 1개
      • Use the flat end of a spudger to press the bottom edge of the lower optical drive bracket release tab toward the lower edge of the iMac.
      • The optical drive should now be free from the rear case.
      • Maneuver the optical drive out of the rear case, minding the two plastic pins molded into the rear case near the open end of the optical drive that can break off.
      댓글 쓰기
    1. iMac G5 17" Model A1144 Optical Drive Replacement, Optical Drive: 23 단계, 이미지 1개 중 1개
      • Remove the two T10 Torx screws from the side of your optical drive.
      댓글 쓰기
    2. iMac G5 17" Model A1144 Optical Drive Replacement: 24 단계, 이미지 2개 중 1개 iMac G5 17" Model A1144 Optical Drive Replacement: 24 단계, 이미지 2개 중 2개
      • Push the two optical drive bracket tabs out of their slots in the top of the optical drive.
      댓글 쓰기
    3. iMac G5 17" Model A1144 Optical Drive Replacement: 25 단계, 이미지 1개 중 1개
      • Using the tip of a spudger, press the optical drive bracket tab out of its slot on the side of the optical drive.
      댓글 쓰기
    4. iMac G5 17" Model A1144 Optical Drive Replacement: 26 단계, 이미지 2개 중 1개 iMac G5 17" Model A1144 Optical Drive Replacement: 26 단계, 이미지 2개 중 2개
      • Use the tip of a spudger to push the optical drive bracket tabs out of their slots on the bottom of the optical drive.
      댓글 쓰기
    5. iMac G5 17" Model A1144 Optical Drive Replacement: 27 단계, 이미지 2개 중 1개 iMac G5 17" Model A1144 Optical Drive Replacement: 27 단계, 이미지 2개 중 2개
      • Pull the optical drive bracket toward the open end of the optical drive to free it from the optical drive.
      • Set the bracket aside.
      댓글 쓰기
    6. iMac G5 17" Model A1144 Optical Drive Replacement: 28 단계, 이미지 1개 중 1개
      • Remove the two T6 Torx screws securing the optical drive flex cable to the optical drive.
      댓글 쓰기
    7. iMac G5 17" Model A1144 Optical Drive Replacement: 29 단계, 이미지 2개 중 1개 iMac G5 17" Model A1144 Optical Drive Replacement: 29 단계, 이미지 2개 중 2개
      • Insert the flat end of a spudger into the gap between the optical drive flex cable connector and the optical drive.
      • Twist the spudger to separate the connector from the optical drive.
      • Repeat this process for both sides of the connector.
      댓글 쓰기
    8. iMac G5 17" Model A1144 Optical Drive Replacement: 30 단계, 이미지 1개 중 1개
      • Pull the optical drive flex cable connector away from the optical drive.
      댓글 쓰기
    9. iMac G5 17" Model A1144 Optical Drive Replacement: 31 단계, 이미지 1개 중 1개
      • Use a spudger to pry the optical drive thermal sensor off the optical drive.
      • Don't forget to transfer this to your new drive.
      댓글 쓰기
    10. iMac G5 17" Model A1144 Optical Drive Replacement: 32 단계, 이미지 1개 중 1개
      • Use the flat end of a spudger to remove the small piece of EMI foam from the underside of the optical drive.
      • Your optical drive is now completely stripped. If you have a disk or anything else stuck inside your optical drive, we have a guide to fix it.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Walter Galan
710,532 평판
안내서 1,203개를 작성함
1가이드 댓글
Excellent information that is timely for me because I need to replace my hard disk. Do you recall the name of the hard disk you used to replace the original, just quickly?
fnf mod
blanda luciano - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 19
지난 30일: 50
전체 시간: 12,860
