주요 콘텐츠로 건너뛰기
iMac G5 20" Model A1076 PRAM Battery Replacement
Andrew Bookholt
Andrew Bookholt5 다른 기여자
최종 수정일 May 14, 2024
예상시간 없음
조정
Use this guide to replace your CR2032 PRAM battery.
필요한 것
부품
도구
더보기...
  1. iMac G5 20" Model A1076 PRAM Battery Replacement, Rear Panel: 1 단계, 이미지 1개 중 1개
    • Lay the iMac display-side down on a flat surface (putting a cloth under the screen to protect it from bumps).
    • Loosen the three Phillips screws securing the rear panel to the iMac.
    • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
  2. iMac G5 20" Model A1076 PRAM Battery Replacement: 2 단계, 이미지 2개 중 1개 iMac G5 20" Model A1076 PRAM Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Lift the rear panel slightly near the bottom of the iMac.
    • Pull the rear panel toward yourself and remove it from the iMac.
  3. iMac G5 20" Model A1076 PRAM Battery Replacement, AirPort Extreme: 3 단계, 이미지 1개 중 1개
    • Lift the AirPort card slightly by its plastic tab and pull it straight away from its socket.
    • During reinstallation, insert the AirPort card such that the antenna side is nearest the center of the logic board.
  4. iMac G5 20" Model A1076 PRAM Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Insert the flat end of a spudger between the body of the AirPort card and its antenna connector.
    • Push the spudger away from the AirPort card to disconnect the AirPort antenna.
    • When reassembling your iMac, be sure to insert the AirPort card the way it was before disassembly.
  5. iMac G5 20" Model A1076 PRAM Battery Replacement, PRAM Battery: 5 단계, 이미지 1개 중 1개
    • Remove the two 5.5 mm T6 Torx screws securing the AirPort bracket to the logic board.
  6. iMac G5 20" Model A1076 PRAM Battery Replacement: 6 단계, 이미지 2개 중 1개 iMac G5 20" Model A1076 PRAM Battery Replacement: 6 단계, 이미지 2개 중 2개
    • Slightly lift the AirPort bracket off the logic board.
    • De-route the AirPort antenna through the slot in the AirPort bracket.
  7. iMac G5 20" Model A1076 PRAM Battery Replacement: 7 단계, 이미지 1개 중 1개
    • Use a spudger to slide the PRAM battery out from under its socket's metal clip.
    • Do not bend the metal clip up, as it is brittle and will break.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Andrew Bookholt
591,946 평판
안내서 619개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 7
전체 시간: 11,654
