주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iMac Intel 21.5" EMC 2428 RAM Replacement
필요한 것
    1. iMac Intel 21.5" EMC 2428 RAM Replacement, Access Door: 1 단계, 이미지 2개 중 1개 iMac Intel 21.5" EMC 2428 RAM Replacement, Access Door: 1 단계, 이미지 2개 중 2개
      • Unplug your iMac's AC cord along with any peripheral devices.
      • Lay your iMac face-down on a soft, clean surface as shown.
      • Be sure there isn't any dirt or debris on your work surface, as it may scratch the glass panel on the front of your iMac. We recommend placing a towel between the iMac and the work surface.
      • Loosen the three Phillips screws securing the access door to the bottom edge of your iMac.
      • All three screws will remain captive in the access door.
      • Remove the access door.
      댓글 쓰기
    1. iMac Intel 21.5" EMC 2428 RAM Replacement, RAM: 2 단계, 이미지 3개 중 1개 iMac Intel 21.5" EMC 2428 RAM Replacement, RAM: 2 단계, 이미지 3개 중 2개 iMac Intel 21.5" EMC 2428 RAM Replacement, RAM: 2 단계, 이미지 3개 중 3개
      • Gently slide the black plastic RAM pull tab out from the RAM slot.
      • Pull the black plastic tab away from the bottom edge of the iMac to eject the module(s) on that side of the RAM bay.
      • This may require a bit of force.
      댓글 쓰기
    2. iMac Intel 21.5" EMC 2428 RAM Replacement: 3 단계, 이미지 1개 중 1개
      • Slide the old RAM module(s) out of their slots in the RAM bay and set them aside.
      댓글 쓰기
    3. iMac Intel 21.5" EMC 2428 RAM Replacement: 4 단계, 이미지 3개 중 1개 iMac Intel 21.5" EMC 2428 RAM Replacement: 4 단계, 이미지 3개 중 2개 iMac Intel 21.5" EMC 2428 RAM Replacement: 4 단계, 이미지 3개 중 3개
      • Repeat the process in the previous steps to remove the RAM module(s) from the other side of the RAM bay.
      댓글 쓰기
    4. iMac Intel 21.5" EMC 2428 RAM Replacement: 5 단계, 이미지 3개 중 1개 iMac Intel 21.5" EMC 2428 RAM Replacement: 5 단계, 이미지 3개 중 2개 iMac Intel 21.5" EMC 2428 RAM Replacement: 5 단계, 이미지 3개 중 3개
      • When installing new RAM modules, it is important to orient them correctly.
      • Be sure the small notch cut into each RAM module (shown in the first picture) mates with the protrusion in each RAM slot (shown in the second picture).
      • Your iMac has four RAM slots. Be sure to slide each RAM module into its slot horizontally. This will prevent getting the modules stuck between two of the adjacent slots.
      • Once you have oriented the new RAM modules correctly, gently slide them completely into the iMac and use your thumbs to firmly seat them in their sockets.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 135명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Walter Galan
710,638 평판
안내서 1,203개를 작성함
5가이드 댓글
Considering cautions against mixing RAM it would seem my 2009 imac can only be helped by ripping out original 4, 1G Ram modules and replacing with 4 @moreG as "cheapest "way to upgrade which seems ridiculous compared to changing one or 2 modules. Is this another stupidity of our computer world?
Harol Smage
harolds - 답글 공유
Thank you this worked really well!
Reid Fleishman - 답글 공유
When inserted new 2x4GB modules in addition to the original 2x2GB modules to iMac mid 2011, it was only beeping on power off. Tried to swap all module placements around couple of times before they were all accepted. Now with 12GB total ram.
Jozef Kutej - 답글 공유
I'm assuming that I could replace all 4 ram slots with 4x8gb chips above?? Would this work?
iMac (21.5-inch, Mid 2011) 2.5 GHz Intel Core i5
current ram 12 GB 1333 MHz DDR3
I want to replace 2 current chips if not all 4 with this PC3-10600 8 GB RAM Chip
joemangrum - 답글 공유
I have just removed 2 x 2 GB ram modules and replaced with 2 x 4GB?
'Could' the 2x2GB modules be stuck back in also, or no?
Dave heath - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 47
지난 30일: 226
전체 시간: 99,237
