주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iPad Mini Home button Replacement
필요한 것
  1. iPad Mini Home button Replacement, Reveal solder pads: 1 단계, 이미지 1개 중 1개
    • Use heat to losen the adhesive. A low temp hot air gun will suffice.
    • After heating up the adhesive, you can use a basic spudger to pry off the flex from the glass
    • be sure not to use too much force, this flex is very fragile.
    댓글 쓰기
  2. iPad Mini Home button Replacement, Apply your own solder: 2 단계, 이미지 1개 중 1개
    • use your iron, and low guage solder to apply a layer of your own solder on the pads
    • the new solder will allow for faster, and more controlled heat transfer.
    댓글 쓰기
  3. iPad Mini Home button Replacement, Remove the flex: 3 단계, 이미지 1개 중 1개
    • a few back and forth strokes of your soldering iron should be enough to remove the flex cable.
    • be sure not to apply too much force with the iron, as you can cause physical damage to the pads.
    • Using a little bit of solder flux, can help decrease the amount of pressure needed to properly transfer the heat.
    댓글 쓰기
  4. iPad Mini Home button Replacement, Line up the pads: 4 단계, 이미지 1개 중 1개
    • be sure to make sure you can see directly through the holes marked on both sides.
    • Line the corrisponding holes up, and make sure they are 100% overlapped.
    • failing to properly line up the holes can cause a short, or cold circuit.
    댓글 쓰기
  5. iPad Mini Home button Replacement, Re-Solder: 5 단계, 이미지 1개 중 1개
    • Use the new solder you added, to connect to the flex.
    • be sure to cover the traces with some electrical tape to avoid shorts.
    • congratulations on your home button replacement
    댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Scott
회원 가입일: 10/09/13
9,937 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 16
지난 30일: 70
전체 시간: 13,155
