주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iPhone 15 Pro Max Back Glass Replacement
필요한 것
    1. iPhone 15 Pro Max Back Glass Replacement, Prepare your phone for disassembly: 1 단계, 이미지 2개 중 1개 iPhone 15 Pro Max Back Glass Replacement, Prepare your phone for disassembly: 1 단계, 이미지 2개 중 2개
      • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
      • Unplug any cables from your phone.
      • Hold the power and either volume buttons and slide to power off your phone.
      댓글 쓰기
    2. iPhone 15 Pro Max Back Glass Replacement, Tape over any cracks: 2 단계, 이미지 2개 중 1개 iPhone 15 Pro Max Back Glass Replacement, Tape over any cracks: 2 단계, 이미지 2개 중 2개
      • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
      • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
      댓글 쓰기
    1. iPhone 15 Pro Max Back Glass Replacement, Mark your opening picks: 3 단계, 이미지 3개 중 1개 iPhone 15 Pro Max Back Glass Replacement, Mark your opening picks: 3 단계, 이미지 3개 중 2개 iPhone 15 Pro Max Back Glass Replacement, Mark your opening picks: 3 단계, 이미지 3개 중 3개
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      댓글 쓰기
    1. iPhone 15 Pro Max Back Glass Replacement, Remove the pentalobe screws: 4 단계, 이미지 1개 중 1개
      • Use a P2 pentalobe driver to remove the two 7.2 mm-long screws on either side of the charging port.
      댓글 쓰기
    1. iPhone 15 Pro Max Back Glass Replacement, Heat the bottom edge: 5 단계, 이미지 1개 중 1개
      • Use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
      • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
      댓글 쓰기
    2. iPhone 15 Pro Max Back Glass Replacement, Insert an opening pick: 6 단계, 이미지 3개 중 1개 iPhone 15 Pro Max Back Glass Replacement, Insert an opening pick: 6 단계, 이미지 3개 중 2개 iPhone 15 Pro Max Back Glass Replacement, Insert an opening pick: 6 단계, 이미지 3개 중 3개
      • Apply a suction handle to the bottom edge of the back glass.
      • Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
      • Insert the tip of an opening pick into the gap.
      댓글 쓰기
    3. iPhone 15 Pro Max Back Glass Replacement, Back glass information: 7 단계, 이미지 1개 중 1개
      • As you slice the adhesive securing the back glass in the next steps, be careful of the wireless charging cable near the volume buttons.
      댓글 쓰기
    4. iPhone 15 Pro Max Back Glass Replacement, Separate the bottom edge adhesive: 8 단계, 이미지 3개 중 1개 iPhone 15 Pro Max Back Glass Replacement, Separate the bottom edge adhesive: 8 단계, 이미지 3개 중 2개 iPhone 15 Pro Max Back Glass Replacement, Separate the bottom edge adhesive: 8 단계, 이미지 3개 중 3개
      • Don't insert your opening pick deeper than 5 mm along the bottom edge.
      • Slide your pick back and forth along the bottom edge to separate the adhesive.
      • Leave your pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
      댓글 쓰기
    5. iPhone 15 Pro Max Back Glass Replacement, Heat the left edge: 9 단계, 이미지 1개 중 1개
      • Heat the left edge of the back glass until it's hot to the touch.
      댓글 쓰기
    6. iPhone 15 Pro Max Back Glass Replacement, Separate the left edge adhesive: 10 단계, 이미지 2개 중 1개 iPhone 15 Pro Max Back Glass Replacement, Separate the left edge adhesive: 10 단계, 이미지 2개 중 2개
      • Don't insert your pick deeper than 5 mm along the left edge.
      • Insert a second opening pick to the left of the first one.
      • Slide this pick to the top left corner of the back glass to separate the left edge adhesive.
      • Leave this pick inserted to prevent the adhesive from resealing.
      댓글 쓰기
    7. iPhone 15 Pro Max Back Glass Replacement, Heat the top edge: 11 단계, 이미지 1개 중 1개
      • Heat the top edge of the back glass until it's hot to the touch.
      댓글 쓰기
    8. iPhone 15 Pro Max Back Glass Replacement, Separate the top edge adhesive: 12 단계, 이미지 3개 중 1개 iPhone 15 Pro Max Back Glass Replacement, Separate the top edge adhesive: 12 단계, 이미지 3개 중 2개 iPhone 15 Pro Max Back Glass Replacement, Separate the top edge adhesive: 12 단계, 이미지 3개 중 3개
      • Don't insert your pick deeper than 5 mm along the top edge.
      • Insert a third opening pick in the top left corner of the back glass.
      • Slide your pick to the top right corner to separate the top edge adhesive.
      • If the top edge of the back glass doesn't separate, the top clips may be stuck. Use the flat end of a spudger to press the clips inward until they release.
      댓글 쓰기
    9. iPhone 15 Pro Max Back Glass Replacement, Separate the top right corner adhesive: 13 단계, 이미지 3개 중 1개 iPhone 15 Pro Max Back Glass Replacement, Separate the top right corner adhesive: 13 단계, 이미지 3개 중 2개 iPhone 15 Pro Max Back Glass Replacement, Separate the top right corner adhesive: 13 단계, 이미지 3개 중 3개
      • Don't slide your pick past the volume up button to avoid slicing the wireless charging cable.
      • Rotate your pick around the top right corner of the back glass.
      • Slide your pick to the volume up button.
      • Leave this pick in place to prevent the adhesive from resealing.
      댓글 쓰기
    10. iPhone 15 Pro Max Back Glass Replacement, Heat the right edge: 14 단계, 이미지 1개 중 1개
      • Heat the right edge of the back glass until it's hot to the touch.
      댓글 쓰기
    11. iPhone 15 Pro Max Back Glass Replacement, Separate the right edge adhesive: 15 단계, 이미지 3개 중 1개 iPhone 15 Pro Max Back Glass Replacement, Separate the right edge adhesive: 15 단계, 이미지 3개 중 2개 iPhone 15 Pro Max Back Glass Replacement, Separate the right edge adhesive: 15 단계, 이미지 3개 중 3개
      • Don't slide your pick past the volume down button to avoid slicing the wireless charging cable.
      • Insert a fourth opening pick at the bottom edge of the back glass.
      • Rotate your pick around the bottom right corner of the back glass.
      • Slide your pick to the volume down button.
      댓글 쓰기
    12. iPhone 15 Pro Max Back Glass Replacement, Swing open the back glass: 16 단계, 이미지 3개 중 1개 iPhone 15 Pro Max Back Glass Replacement, Swing open the back glass: 16 단계, 이미지 3개 중 2개 iPhone 15 Pro Max Back Glass Replacement, Swing open the back glass: 16 단계, 이미지 3개 중 3개
      • Gently swing open the back glass over the right edge of the phone.
      • If the back glass feels stuck, go back around the perimeter to check for missed sections of adhesive or stuck clips.
      • Rest the back glass against a box or similar object so it doesn't strain the cable.
      댓글 쓰기
    13. iPhone 15 Pro Max Back Glass Replacement, Remove the wireless charging connector cover: 17 단계, 이미지 3개 중 1개 iPhone 15 Pro Max Back Glass Replacement, Remove the wireless charging connector cover: 17 단계, 이미지 3개 중 2개 iPhone 15 Pro Max Back Glass Replacement, Remove the wireless charging connector cover: 17 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Use a tri-point Y000 driver to remove the 1.0 mm‑long screw securing the wireless charging connector cover.
      • Use tweezers to slide the cover out of its slot on the logic board and remove it.
      댓글 쓰기
    14. iPhone 15 Pro Max Back Glass Replacement, Disconnect the wireless charging coil: 18 단계, 이미지 2개 중 1개 iPhone 15 Pro Max Back Glass Replacement, Disconnect the wireless charging coil: 18 단계, 이미지 2개 중 2개
      • Use the tip of an opening pick to pry up and disconnect the wireless charging coil press connector.
      • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side.
      댓글 쓰기
    15. iPhone 15 Pro Max Back Glass Replacement, Remove the back glass: 19 단계, 이미지 2개 중 1개 iPhone 15 Pro Max Back Glass Replacement, Remove the back glass: 19 단계, 이미지 2개 중 2개
      • Remove the back glass.
      댓글 쓰기
    1. iPhone 15 Pro Max Back Glass Replacement, Disassembly complete: 20 단계, 이미지 1개 중 1개
      • Congratulations on completing disassembly! The remaining steps show how to reassemble the iPhone.
      • Depending on your iPhone model, some reassembly photos may have minor visual discrepancies. The procedure will be correct.
      댓글 쓰기
    1. iPhone 15 Pro Max Back Glass Replacement, Remove the back glass adhesive: 21 단계, 이미지 3개 중 1개 iPhone 15 Pro Max Back Glass Replacement, Remove the back glass adhesive: 21 단계, 이미지 3개 중 2개 iPhone 15 Pro Max Back Glass Replacement, Remove the back glass adhesive: 21 단계, 이미지 3개 중 3개
      • The back glass adhesive is very sticky may take a while to remove.
      • Use the point of a spudger to ball up a larger section of adhesive and remove it from the frame.
      • If the adhesive is stubborn, warm it up with a hair dryer or heat gun to soften it.
      • Repeat this process until all the larger strips of adhesive are removed.
      댓글 쓰기
    2. iPhone 15 Pro Max Back Glass Replacement: 22 단계, 이미지 3개 중 1개 iPhone 15 Pro Max Back Glass Replacement: 22 단계, 이미지 3개 중 2개 iPhone 15 Pro Max Back Glass Replacement: 22 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      iFixit Adhesive Remover
      $19.99
      • Apply a few drops of adhesive remover or high-concentration (90% or higher) isopropyl alcohol to a cotton swab or coffee filter.
      • Wipe the residual adhesive off the frame.
      댓글 쓰기
    3. iPhone 15 Pro Max Back Glass Replacement: 23 단계, 이미지 3개 중 1개 iPhone 15 Pro Max Back Glass Replacement: 23 단계, 이미지 3개 중 2개 iPhone 15 Pro Max Back Glass Replacement: 23 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      $19.99
      • Apply a few drops of adhesive remover or high-concentration (90% or higher) isopropyl alcohol to a clean lint‑free cloth or coffee filter and wipe all residual adhesive off the frame to prep the surface for the new adhesive.
      댓글 쓰기
    4. iPhone 15 Pro Max Back Glass Replacement, Orient the replacement adhesive: 24 단계, 이미지 1개 중 1개
      • Without peeling any liners, lay the adhesive sheet over the frame to determine its orientation.
      • Use features such as the camera cutout and notches along the edges to visualize how the adhesive will lay on the frame.
      댓글 쓰기
    5. iPhone 15 Pro Max Back Glass Replacement, Apply the replacement adhesive: 25 단계, 이미지 1개 중 1개
      • Grab the large tab in the bottom corner of the adhesive sheet and begin peeling off the liner that exposes the side that sticks to the frame. Don't remove it all the way.
      • The exposed adhesive is very sticky. Don't let it touch anything until you're ready to apply it to the frame.
      • If your adhesive has multiple liners, peel the liner that exposes the side that sticks to the frame.
      댓글 쓰기
    6. iPhone 15 Pro Max Back Glass Replacement: 26 단계, 이미지 3개 중 1개 iPhone 15 Pro Max Back Glass Replacement: 26 단계, 이미지 3개 중 2개 iPhone 15 Pro Max Back Glass Replacement: 26 단계, 이미지 3개 중 3개
      • Once the adhesive is set into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
      • While holding the back liner out of the way, carefully align the exposed edge of the adhesive to the bottom edge of the iPhone's frame.
      • When the adhesive is aligned, set it down along the bottom edge.
      댓글 쓰기
    7. iPhone 15 Pro Max Back Glass Replacement: 27 단계, 이미지 2개 중 1개 iPhone 15 Pro Max Back Glass Replacement: 27 단계, 이미지 2개 중 2개
      • Use the flat end of a spudger to press the adhesive into place along the bottom edge.
      댓글 쓰기
    8. iPhone 15 Pro Max Back Glass Replacement: 28 단계, 이미지 3개 중 1개 iPhone 15 Pro Max Back Glass Replacement: 28 단계, 이미지 3개 중 2개 iPhone 15 Pro Max Back Glass Replacement: 28 단계, 이미지 3개 중 3개
      • Continue peeling the back liner off of the adhesive and setting the adhesive into place along the edges of the iPhone's frame.
      • If you correctly aligned the lower edge of the adhesive, the side and top edges will fall perfectly into place. If the adhesive is misaligned, remove it and start over with new adhesive.
      • If you don't have another one handy, it's okay to put your iPhone back together without adhesive, but keep in mind that it won't be water resistant until you install new adhesive.
      댓글 쓰기
    9. iPhone 15 Pro Max Back Glass Replacement, Press the adhesive into place: 29 단계, 이미지 3개 중 1개 iPhone 15 Pro Max Back Glass Replacement, Press the adhesive into place: 29 단계, 이미지 3개 중 2개 iPhone 15 Pro Max Back Glass Replacement, Press the adhesive into place: 29 단계, 이미지 3개 중 3개
      • Use the flat end of a spudger to press the adhesive into place all around the iPhone.
      댓글 쓰기
    10. iPhone 15 Pro Max Back Glass Replacement, Remove the top liner: 30 단계, 이미지 3개 중 1개 iPhone 15 Pro Max Back Glass Replacement, Remove the top liner: 30 단계, 이미지 3개 중 2개 iPhone 15 Pro Max Back Glass Replacement, Remove the top liner: 30 단계, 이미지 3개 중 3개
      • Lift the pull tab in the top‑right corner of the frame to peel off the top liner and remove it.
      • Your pull tab may be in a different location. Make sure you're pulling the full-size top liner, not the thin liners along the edges.
      댓글 쓰기
    11. iPhone 15 Pro Max Back Glass Replacement, Adhesive information: 31 단계, 이미지 1개 중 1개
      • Once the top liner is removed, there should be three narrow liners on top of the adhesive with pull tabs near the bottom edge.
      • Your pull tabs may be in different positions.
      • If you don't see these pull tabs, you may have accidentally removed the thin liners in the previous step. Be careful not to touch anything to the exposed adhesive.
      댓글 쓰기
    12. iPhone 15 Pro Max Back Glass Replacement, Align the back glass: 32 단계, 이미지 2개 중 1개 iPhone 15 Pro Max Back Glass Replacement, Align the back glass: 32 단계, 이미지 2개 중 2개
      • Set the back glass on the right edge of the iPhone frame and use one hand to hold it in place.
      댓글 쓰기
    13. iPhone 15 Pro Max Back Glass Replacement, Connect the back glass: 33 단계, 이미지 2개 중 1개 iPhone 15 Pro Max Back Glass Replacement, Connect the back glass: 33 단계, 이미지 2개 중 2개
      • Use the flat end of a spudger or your finger to connect the back glass press connector.
      댓글 쓰기
    14. iPhone 15 Pro Max Back Glass Replacement, Install the wireless charging connector cover: 34 단계, 이미지 3개 중 1개 iPhone 15 Pro Max Back Glass Replacement, Install the wireless charging connector cover: 34 단계, 이미지 3개 중 2개 iPhone 15 Pro Max Back Glass Replacement, Install the wireless charging connector cover: 34 단계, 이미지 3개 중 3개
      • Use tweezers to slide the tab on the wireless charging connector cover into its slot on the board and set it into place.
      • Use a tri-point Y000 driver to install the 1.0 mm‑long screw securing the wireless charging connector cover.
      댓글 쓰기
    15. iPhone 15 Pro Max Back Glass Replacement, Remove the final adhesive liners: 35 단계, 이미지 3개 중 1개 iPhone 15 Pro Max Back Glass Replacement, Remove the final adhesive liners: 35 단계, 이미지 3개 중 2개 iPhone 15 Pro Max Back Glass Replacement, Remove the final adhesive liners: 35 단계, 이미지 3개 중 3개
      • Hold the back glass over the phone so you can access the narrow liner covering the adhesive on the right edge of the frame.
      • Use tweezers to remove the narrow liner on the right edge.
      댓글 쓰기
    16. iPhone 15 Pro Max Back Glass Replacement: 36 단계, 이미지 2개 중 1개 iPhone 15 Pro Max Back Glass Replacement: 36 단계, 이미지 2개 중 2개
      • Remove the remaining narrow liners to fully expose the back glass adhesive.
      댓글 쓰기
    17. iPhone 15 Pro Max Back Glass Replacement, Install the back glass: 37 단계, 이미지 3개 중 1개 iPhone 15 Pro Max Back Glass Replacement, Install the back glass: 37 단계, 이미지 3개 중 2개 iPhone 15 Pro Max Back Glass Replacement, Install the back glass: 37 단계, 이미지 3개 중 3개
      • Align the back glass over the frame and press it into place.
      댓글 쓰기
    18. iPhone 15 Pro Max Back Glass Replacement: 38 단계, 이미지 2개 중 1개 iPhone 15 Pro Max Back Glass Replacement: 38 단계, 이미지 2개 중 2개
      • Firmly press along the edges of the phone to compress the adhesive and engage the clips.
      댓글 쓰기
    19. iPhone 15 Pro Max Back Glass Replacement, Install the pentalobe screws: 39 단계, 이미지 1개 중 1개
      • Use a P2 pentalobe screwdriver to install the two 7 mm‑long screws on either side of the charging port.
      댓글 쓰기
    20. iPhone 15 Pro Max Back Glass Replacement, Heat the back glass: 40 단계, 이미지 2개 중 1개 iPhone 15 Pro Max Back Glass Replacement, Heat the back glass: 40 단계, 이미지 2개 중 2개
      • To help the adhesive bond, apply heat to the edges of the back glass using a hair dryer or heat gun until it's hot to the touch.
      댓글 쓰기
    1. iPhone 15 Pro Max Back Glass Replacement, Press the back glass: 41 단계, 이미지 3개 중 1개 iPhone 15 Pro Max Back Glass Replacement, Press the back glass: 41 단계, 이미지 3개 중 2개 iPhone 15 Pro Max Back Glass Replacement, Press the back glass: 41 단계, 이미지 3개 중 3개
      • To evenly compress the iPhone and strengthen the bond of the screen to the frame, you need to account for the camera bump.
      • If you have the iPhone's original box, take the lid and place it on a flat surface.
      • If you don't have the original box, skip this step for an alternate method.
      • Place the iPhone screen-side-up in the lid of the box with the camera bump in its recess.
      • Find something close to the size of the iPhone, but taller than the sides of the box. Stack it on top of the iPhone, followed by a few heavy objects.
      • Leave the objects in place for at least thirty minutes, ideally overnight.
      댓글 쓰기
    2. iPhone 15 Pro Max Back Glass Replacement: 42 단계, 이미지 3개 중 1개 iPhone 15 Pro Max Back Glass Replacement: 42 단계, 이미지 3개 중 2개 iPhone 15 Pro Max Back Glass Replacement: 42 단계, 이미지 3개 중 3개
      • If you don't have the iPhone's original box, follow the these two steps for another method to evenly compress the screen.
      • Place the iPhone screen-side-down on a soft, flat surface.
      • Apply tape to the back glass to protect its finish.
      • Place three layers of coins or similarly thick objects on the tape along the edges of the back glass.
      • Evenly distribute the coins and make sure they are at least as thick as the camera bump.
      댓글 쓰기
    3. iPhone 15 Pro Max Back Glass Replacement: 43 단계, 이미지 1개 중 1개
      • Stack multiple books or other heavy objects on your iPhone.
      • The coins may leave an impression on the bottom object, so don't use anything valuable.
      댓글 쓰기
결론
Congratulations on finishing the repair!
If you have trouble with wireless charging, try running Apple’s Repair Assistant.
Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
취소: 해당 안내서를 완성하지 않았습니다.
다른 47명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Clay Eickemeyer
회원 가입일: 09/19/22
105,616 평판
안내서 472개를 작성함
Guide Team Guide Team 회원
Staff
10 회원들
안내서 23,248개를 작성함
5가이드 댓글
Is there a recommended source for getting a new back glass? Either OEM or non-OEM.
Taylor - 답글 공유
I’m looking for the same answer can’t find oem quality back glass of iphone
Shehroz Shehzad - 답글 공유
Great instructions, but where do we get a new replacement back glass from? Please suggest.
rubenhak - 답글 공유
Apple's OEM parts are available through SelfServiceRepair.com, including the back glass for this iPhone. None of the aftermarket stores I'd generally recommend carry this part, but it looks like there's quite a few options on marketplace sites. The best advice I can give there is to look at seller reviews, and when possible, feedback for that specific part. Best of luck!
Nick Schultz - 답글 공유
怎么在不更换无线充线圈的情况下更换后壳
menglei Ren - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 119
지난 7일: 726
지난 30일: 3,543
전체 시간: 108,074
