소개
If you have to use speakerphone to get audio in a phone call, you may need to replace your earpiece speaker. Use this guide to replace a dead or dying earpiece speaker in your iPhone 6.
You can also use this guide to replace the following parts:
Power off your iPhone before beginning disassembly.
Remove the two 3.6 mm-long Pentalobe screws next to the Lightning connector.
If the plastic depth gauge is attached at the center of the iSclack, remove it now—it's not needed for larger phones like the iPhone 6.
Close the handle on the iSclack, opening the suction-cup jaws.
Place the bottom of your iPhone in between the suction cups.
Position the iSclack's upper suction cup against the display, just above (but not covering) the home button.
Open the handles to close the jaws of the iSclack. Center the suction cups and press them firmly onto the top and bottom of the iPhone.
Hold onto your iPhone securely and close the handle of the iSclack to separate the suction cups, pulling the front panel up from the rear case.
The iSclack is designed to safely open your iPhone just enough to separate the pieces, but not enough to damage the display cables.
Peel the two suction cups off your iPhone.
Skip the next three steps and continue on to Step 8.
If you don't have an iSclack, use a single suction cup to lift the front panel:
Press a suction cup onto the screen, just above the home button.
Open the iPhone by swinging the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
Remove the following Phillips screws from the battery connector bracket:
One 2.2 mm screw
One 3.2 mm screw
Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
Remove the following five Phillips screws securing the front panel assembly cable bracket:
Three 1.2 mm screws
One 1.7 mm screw
One 3.1 mm screw
Remove the front panel assembly from the rear case.
Remove the following Phillips screws from the earpiece speaker/front-facing camera bracket:
One 2.3 mm screw
One 3.0 mm screw
One 2.2 mm screw
다른 294명이 해당 안내서를 완성하였습니다.
댓글 25개
Holy crap, ordered the replacement speaker and the $24 tool kit, followed this website and in 15 minutes (plus a baby diaper change in the middle) my wife's iphone 6 was working through the ear piece again! Super informative instructions - I like the color code on the screw sizes so I could sort them in trays during removal. Thank you ifixit! You saved me hundreds of dollars! The hardest part was snapping the cable connectors back in, I was very cautious not to force them in but other than that it was a breeze.
What kit would you recommend me?
ceaggar -
My husband dropped his iPhone 6 in a glass of water. He immediately pulled out, dried it and put it in a glass with rice. He tried to arrest him but did not work. He opened it and had water. it dried, he reassembled but did not detect the SIM card. The phone works but is not heard nothing.
I just changed the ear speaker on my iphone 6. The damage was caused by water. After thr replacement and a full factory reset the ear speaker is still not working. I read that it could be the cable however the camera, proximity sensor and everything else seems to be working, only the ear speaker still doesnt work.
Any ideas?
Thanks
