소개
이 안내서를 사용하여 이어피스 스피커를 교체하세요.
분해를 시작하기 전에 iPhone 전원을 끄세요.
Lightning 커넥터 옆에 위치한 3.6mm-길이 P2 Pentalobe/펜타로브/별나사 두 개를 풀어주세요.
플라스틱 깊이 게이지가 iSclack 중앙에 부착되어 있다면 지금 분리하세요—iPhone 6 Plus 처럼 대형 휴대폰에는 필요없습니다.
iSclack 핸들을 닫아서, 흡입컵 턱을 여세요.
iPhone 하단을 흡입 컵 사이에 놓으세요.
손잡이를 열어서 iSclack 턱을 닫으세요. 흡입 컵을 중앙에 맞추고 iPhone 상단과 하단에 단단히 누르세요.
기기를 다시 조립하려면 위의 단계를 역순으로 따르세요.
다른 89명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
Christian Kim님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 7개
Dropped my iphone and the speaker stopped working.
Expected that it was a connector that was lose.
Used this guide to fix it.... Thanks :)
My son was chewing on my phone and the speaker was real quiet afterwards. I purchased your product above and installed but nothing changed. Not sure what else it could be, don't want to purchase a 100$ display only to have that not fix the issue either. And of course since I've already opened it Apple sent it back to me :D
After dropping my iPhone from the car, the speaker stopped working. Thankfully using this guide I was able to reseat the connector and all was good again. Make sure the four cable are attached properly to the board when reassembling as I had to take the protective covers back off again and reseat them.
Overall I feel confident that I would be able to do it again.
On a separate note I would highly recommend a decent precision set to carry out any repairs on these small devices. The screws are tiny and magnetised tools are a must.
Thanks iFixit!
phone worse off, smh, well i did as it said, i even bought all the tools from them that i needed, now my phone stuck on apple logo, did reset holding power and home button, went back in disconnected reconnect display connection and power cycled disconnecting battery connector, and still stuck on apple logo. followed everything, was careful, dont know if i went wrong, or what
