소개
Follow the steps in this guide to replace the earpiece speaker in your iPhone 6s Plus.
You can also use this guide to replace the earpiece speaker bracket.
필요한 것
Power off your iPhone before beginning disassembly.
Remove the two 3.4 mm Pentalobe screws on either side of the Lightning port.
이 단계에 사용된 도구:Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
If you don't have an Anti-Clamp, follow the next three steps to use a suction handle.
Apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge.
Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
이 단계에 사용된 도구:Magnetic Project Mat$19.95
Remove two Phillips screws securing the battery connector bracket to the logic board, of the following lengths:
One 2.9 mm screw
One 2.3 mm screw
Remove the following Phillips screws:
Three 1.3 mm screws
One 1.6 mm screw
One 3.0 mm screw
Remove the following three Phillips screws:
Two 2.7 mm screws
One 1.4 mm screw
다른 89명이 해당 안내서를 완성하였습니다.
댓글 12개
For future reference, I found only a slight physical difference between the two. Tested both out on a 6s Plus and they both seem to work exactly the same.
Awsome done it
Guide worked well. Fixed my 6s Plus with no issues.
Thanks.
jim crusan - 답글
Is the earpiece bracket the same as the one in the iphone 6s?
