주요 콘텐츠로 건너뛰기
iRobot Roomba 650 Side Brush and Bottom Panel Replacement
Charles Ward
Charles Ward6 다른 기여자
최종 수정일 June 17, 2015
5 분
쉬움
The side brush helps the Roomba to clean around corners. When the side brush wears out, replacement is needed for this component. All the tools you'll need for this is a simple screwdriver. If your Roomba is dirty, it might also be helpful to clean it first.
필요한 것
도구
  1. iRobot Roomba 650 Side Brush and Bottom Panel Replacement, Removing the Side Brush: 1 단계, 이미지 2개 중 1개 iRobot Roomba 650 Side Brush and Bottom Panel Replacement, Removing the Side Brush: 1 단계, 이미지 2개 중 2개
    • With the Roomba upside down and turned off, use the Phillip's 02 screwdriver to remove the one 3.5 mm screw from the center of the side-brush.
    • Set the screw aside and pull the brush out.
  2. iRobot Roomba 650 Side Brush and Bottom Panel Replacement, Bottom Panel Removal: 2 단계, 이미지 2개 중 1개 iRobot Roomba 650 Side Brush and Bottom Panel Replacement, Bottom Panel Removal: 2 단계, 이미지 2개 중 2개
    • Unscrew the four screws that hold the bottom panel using the Phillips 02 screwdriver.
    • The screws will not come out of the bottom panel. They were designed to become loose but not be removed. This prevents you from losing them, and prevents the Roomba from sucking them up if they came out during cleaning.
    • Once you are sure that all the screws have been loosened as much as possible, then lift the bottom panel up off the Roomba.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Charles Ward
회원 가입일: 01/22/15
1,011 평판
안내서 3개를 작성함
Cal Poly, Team 19-7, Maness Winter 2015 Cal Poly, Team 19-7, Maness Winter 2015 회원
CPSU-MANESS-W15S19G7
4 회원들
안내서 6개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 12
지난 30일: 24
전체 시간: 4,640
