주요 콘텐츠로 건너뛰기
iRobot Roomba 891 Drive Wheels Replacement
Justin Tolin
Justin Tolin2 다른 기여자
최종 수정일 August 1, 2019
10 - 30 분
조정
액션 샷
더 나은 이미지가 필요함
누락된 단계
This guide will help you replace the drive wheels on your roomba. This guide highlights the ease of repairability of the roomba and the modular design of this model. The wheels are side specific and sold in pairs. Modules can be purchased at the links included.
  1. iRobot Roomba 891 Drive Wheels Replacement, Battery: 1 단계, 이미지 2개 중 1개 iRobot Roomba 891 Drive Wheels Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Start by flipping your Roomba onto its back on a flat surface.
    • Be sure not to close the side brush bristles in the battery door during reassembly as shown by the handy warning in the second photo.
  2. iRobot Roomba 891 Drive Wheels Replacement: 2 단계, 이미지 1개 중 1개
    • Unscrew both the 11mm Phillips #2 screws from the battery cover and remove cover from the Roomba.
    • These captive screws are not intended to be removed from the cover.
  3. iRobot Roomba 891 Drive Wheels Replacement: 3 단계, 이미지 3개 중 1개 iRobot Roomba 891 Drive Wheels Replacement: 3 단계, 이미지 3개 중 2개 iRobot Roomba 891 Drive Wheels Replacement: 3 단계, 이미지 3개 중 3개
    • Grasp the tabs on either side of the battery.
    • Remove the battery by pulling up on the tabs.
    • While you're here, check the battery contacts for corrosion or debris.
  4. iRobot Roomba 891 Drive Wheels Replacement, Side Brush: 4 단계, 이미지 2개 중 1개 iRobot Roomba 891 Drive Wheels Replacement, Side Brush: 4 단계, 이미지 2개 중 2개
    • Remove the 7.5mm flat head #4 screw from center of the side brush.
  5. iRobot Roomba 891 Drive Wheels Replacement: 5 단계, 이미지 1개 중 1개
    • Gently pull the side brush off of the motor hub.
  6. iRobot Roomba 891 Drive Wheels Replacement, Drive Wheels: 6 단계, 이미지 1개 중 1개
    • Remove dustbin assembly from the Roomba.
  7. iRobot Roomba 891 Drive Wheels Replacement: 7 단계, 이미지 3개 중 1개 iRobot Roomba 891 Drive Wheels Replacement: 7 단계, 이미지 3개 중 2개 iRobot Roomba 891 Drive Wheels Replacement: 7 단계, 이미지 3개 중 3개
    • Remove 2 Phillips #2 11mm screws from the bottom cover.
    • These captive crews are designed to stay in the bottom cover.
    • Remove the bottom cover.
  8. iRobot Roomba 891 Drive Wheels Replacement: 8 단계, 이미지 3개 중 1개 iRobot Roomba 891 Drive Wheels Replacement: 8 단계, 이미지 3개 중 2개 iRobot Roomba 891 Drive Wheels Replacement: 8 단계, 이미지 3개 중 3개
    • Unscrew three Phillips #00 gold 11mm screws from the drive module.
    • Both modules have the same number of screws and are mirror images of each other.
    • Left module is shown in the photos.
  9. iRobot Roomba 891 Drive Wheels Replacement: 9 단계, 이미지 1개 중 1개
    • Grasp wheel module and remove from roomba.
    • Inspect housing for debris.
결론
작성자
2다른 기여자 명과 함께
Justin Tolin
회원 가입일: 05/29/19
718 평판
안내서 5개를 작성함
댓글 한 개
justin i added the word captive to the steps where the screws stayed in place
thomas Wilson - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 17
전체 시간: 599
