주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ionvac SmartClean V2 Battery Replacement
필요한 것
  1. ionvac SmartClean V2 Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Caution: Before beginning, turn off the ionvac and place it on a level surface.
    • Keep in mind that your ionvac has many small screws that can be easily lost. A magnetic project mat is best to prevent misplacing any parts.
    • Flip your ionvac upside down so the wheels are pointed upwards and the side brushes are furthest from you.
    댓글 쓰기
  2. ionvac SmartClean V2 Battery Replacement: 2 단계, 이미지 2개 중 1개 ionvac SmartClean V2 Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the 2 screws that secure the battery door.
    • Lift the battery door to reveal the lithium ion battery.
    • If the battery cover is stuck, use a Jimmy or another prying tool to pry it off.
    댓글 쓰기
  3. ionvac SmartClean V2 Battery Replacement: 3 단계, 이미지 2개 중 1개 ionvac SmartClean V2 Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Disconnect the battery by squeezing down on the cream-colored tabs of the battery connectors and pulling them apart.
    • Caution: Be careful when removing the connector, as the part can break if too much force is used.
    • When reinstalling the battery, remember to place it in your ionvac with the white strip facing up. If the battery has two flaps, ensure the flaps are facing up before screwing in the battery door.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Dylan
회원 가입일: 09/18/23
346 평판
안내서 3개를 작성함
2가이드 댓글
need instructions for installation of battery in TZUMI ion vac smart clean robo vac V4
Eileen Meyer - 답글 공유
need instructions for installation of battery in TZUMI ionvac smart clean robovac V4
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 26
지난 30일: 107
전체 시간: 3,637
