주요 콘텐츠로 건너뛰기
jp.ik Leap T304 Battery Replacement Replacement
Nelson Oliveira
Nelson Oliveira3 다른 기여자
최종 수정일 February 11, 2025
5 분
쉬움
커뮤니티-기여 안내서
You should firstly follow the first guide on how to open the device before proceeding to this guide.
Pay attention to the precautions mentioned in the guide.
필요한 것
도구
더보기...
iFixit은 귀하가 이 링크를 통해 구매할 때 커미션을 받습니다.
  1. jp.ik Leap T304 Battery Replacement Replacement, Rear Cover: 1 단계, 이미지 1개 중 1개
    • First ensure your laptop is turned off and check if you have the necessary tools
  2. jp.ik Leap T304 Battery Replacement Replacement: 2 단계, 이미지 2개 중 1개 jp.ik Leap T304 Battery Replacement Replacement: 2 단계, 이미지 2개 중 2개
    • All screws are identified by circles. Pay special attention to the yellow circles, as the rubber feet hide screws.
  3. jp.ik Leap T304 Battery Replacement Replacement: 3 단계, 이미지 3개 중 1개 jp.ik Leap T304 Battery Replacement Replacement: 3 단계, 이미지 3개 중 2개 jp.ik Leap T304 Battery Replacement Replacement: 3 단계, 이미지 3개 중 3개
    • With the opening tool, remove a rubber foot.
    • For this action you will have to exert some force, because the foot is glued with a resistant glue.
  4. jp.ik Leap T304 Battery Replacement Replacement: 4 단계, 이미지 1개 중 1개
    • Remove all screws with a Philips screwdriver PH1
    • All screws are the same so don't worry about identifying them.
  5. jp.ik Leap T304 Battery Replacement Replacement: 5 단계, 이미지 3개 중 1개 jp.ik Leap T304 Battery Replacement Replacement: 5 단계, 이미지 3개 중 2개 jp.ik Leap T304 Battery Replacement Replacement: 5 단계, 이미지 3개 중 3개
    • With the plastic tool, insert between the plastics and gently pry open.
    • With your fingers continue to force open the bottom cover on the side indicated in the figure.
    • You will feel and hear several clicks, perfectly normal, nothing is breaking. Remove the cover completely.
  6. jp.ik Leap T304 Battery Replacement Replacement: 6 단계, 이미지 1개 중 1개
    • Finally, we have the laptop open and ready to replace most of its components. Look elsewhere on how to replace a component.
    • To close the laptop just follow this guide in reverse.
  7. jp.ik Leap T304 Battery Replacement Replacement, Battery Replacement or Removal: 7 단계, 이미지 1개 중 1개
    • Be careful. Don't touch, if not necessary, any electrical part of the product and ensure you're properly grounded.
  8. jp.ik Leap T304 Battery Replacement Replacement: 8 단계, 이미지 1개 중 1개
    • Remove mylers shown in the picture.
    • Save them for the battery assembly steps.
  9. jp.ik Leap T304 Battery Replacement Replacement: 9 단계, 이미지 2개 중 1개 jp.ik Leap T304 Battery Replacement Replacement: 9 단계, 이미지 2개 중 2개
    • Disconnect the cable marked in the figure gently, pulling it out of the connector.
  10. jp.ik Leap T304 Battery Replacement Replacement: 10 단계, 이미지 2개 중 1개 jp.ik Leap T304 Battery Replacement Replacement: 10 단계, 이미지 2개 중 2개
    • Gently remove the battery.
    • CAUTION!!
    • Some products may have this battery fixed with double-sided adhesive tape. In these cases, use a wide spatula to remove the battery without bending it.
    • SAFETY WARNING!
    • Never bend or puncture the battery. Danger of explosion. If you detect a swollen or damaged battery, handle it with extreme care and place it in a protective container.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Nelson Oliveira
회원 가입일: 02/03/23
741 평판
안내서 4개를 작성함
jp.ik jp.ik 회원
Business
2 회원들
안내서 14개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 31
지난 30일: 73
전체 시간: 636
