주요 콘텐츠로 건너뛰기
why! N240JU Hard disk replacement (mass storage)
필요한 것
  1. why! N240JU Hard disk replacement (mass storage), Battery: 1 단계, 이미지 2개 중 1개 why! N240JU Hard disk replacement (mass storage), Battery: 1 단계, 이미지 2개 중 2개
    • Start by unlocking the right locking latch.
    • Then, by simultaneously unlocking the left latch, lift the battery out of its socket.
  2. why! N240JU Hard disk replacement (mass storage), Access to main components: 2 단계, 이미지 2개 중 1개 why! N240JU Hard disk replacement (mass storage), Access to main components: 2 단계, 이미지 2개 중 2개
    • Begin by spotting the dummy memory card.
    • Then, remove it and put it on your workplan.
  3. why! N240JU Hard disk replacement (mass storage): 3 단계, 이미지 3개 중 1개 why! N240JU Hard disk replacement (mass storage): 3 단계, 이미지 3개 중 2개 why! N240JU Hard disk replacement (mass storage): 3 단계, 이미지 3개 중 3개
    • Locate the 15 screws that hold the bottom cover of the device in place.
    • Unscrew them and place them on your work surface.
    • Then, un-clip the bottom cover, starting with the side shown in the third picture.
  4. why! N240JU Hard disk replacement (mass storage), Hard disk (mass storage): 4 단계, 이미지 3개 중 1개 why! N240JU Hard disk replacement (mass storage), Hard disk (mass storage): 4 단계, 이미지 3개 중 2개 why! N240JU Hard disk replacement (mass storage), Hard disk (mass storage): 4 단계, 이미지 3개 중 3개
    • Locate the hard drive in its location.
    • Lift it slightly.
    • Finally remove it from its SATA connector.
결론
To reassemble your device, Follow these instructions in reverse order.
다음 번역가들에게 특별히 감사 드립니다:
fr en
100%
irlanda님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
작성자
1다른 기여자 명과 함께
Felice Suglia
회원 가입일: 06/15/13
33,538 평판
안내서 283개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 351
