why! W670SZQ1 Replacement Hard Disk (mass storage)
Unlock the lock latch on the left.
Unlock the lock latch on the right.
Remove the battery while holding the lock latch unlocked.
Using the Philips # 0 screwdriver, unscrew the 2 screws from the bottom cover.
Lift the bottom right cover with the iFixit Opening Tool.
Lift the lower left cover with the iFixit Opening Tool.
Finally clear the bottom cover completely to access the main components.
Locate the hard drive with its plastic tab.
Remove the HDD from its SATA port using the plastic tab
To reassemble your device, follow the instructions in reverse order.
다음 번역가들에게 특별히 감사 드립니다:
100%
Israel님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
