기기를 고치세요
수리할 권리
부품 & 도구
MacBook Front Display Bezel
  • MacBook Front Display Bezel / White
  • MacBook Front Display Bezel / Black
US$4.99
US$4.99
제품 재입고 메시지를 보내드리겠습니다.
Essential Electronics Toolkit
Small Toolkit. Big Possibilities.
Shop Toolkits
Essential
Electronics
Toolkit
Shop Toolkits
제품 정보
설명
설명
Replace a scratched or cracked MacBook front display bezel with camera hole.
호환성
호환성
  • All 13.3" MacBooks (excluding MacBook Unibody and MacBook Air)
명세서
명세서
Part #:
922-7776, 922-7598, 922-8009
호환성
MacBook Core 2 Duo
A1181 (EMC 2121) 1.83 GHz
A1181 (EMC 2121) 2 GHz (Late 2006)
A1181 (EMC 2121) 2 GHz (Mid 2007)
A1181 (EMC 2121) 2 GHz (Santa Rosa)
A1181 (EMC 2139) 2.16 GHz
A1181 (EMC 2200) 2.2 GHz (Santa Rosa)
A1181 (EMC 2242) 2.1 GHz (Penryn)
A1181 (EMC 2242) 2.4 GHz (Penryn)
A1181 (EMC 2300) 2 GHz (Early 2009)
A1181 (EMC 2330) 2.13 GHz (Mid 2009)
MacBook Core Duo
A1181 (EMC 2092) 1.83 GHz
A1181 (EMC 2092) 2 GHz
수리 경험담
사용자 아바타
Zachary Wheeling's Story Photo #750163
내 문제
MacBook Core 2 Duo 2.16 Ghz 4GB RAM 240GB Intel SSD 160GB Apple HDD..... Screen Bezel clips were broken and wanted to change color from black to white. Also wanted a dual hard drive as I had recently purchased an SSD to speed up my MacBook C2D and wanted to run three Mac OS's as well as a copy of . . .
사용자 아바타
내 문제
classic cracking in the display bezel and topcase palmrest. Felt like the Mac desirved to be refurbished after the fond college memories
나의 수리
followed the online takeapart guide, was easy as 1 2 3
내 조언
make sure to retain the plastic fitting clips when removing the old front bezel frame, they are needed in ord . . .
사용자 아바타
내 문제
Spilled iced tea all over my upper case and my front bezel was showing some age
나의 수리
It went well thanks to the guides
내 조언
Diy
사용자 아바타
내 문제
Bezel was cracked in assorted places.
The right and left arrow keys quit working.
The trackpad and select (long key below the trackpad) had issues.
나의 수리
I followed the guides and used the plastic bag method to keep track of the screws, at each step I numbered the bag to the step in the instructions. I fou . . .
사용자 아바타
내 문제
Right and Left arrow keys stopped working
The actuator key below the track pad was sticking.
The bezel was cosmetic .
Mac Store wanted almost $400.00 to do the Fix
나의 수리
When I removed the screws with Fixit instructions The some of the screws were in the wrong holes. this unit had been fixed at a
"mac "re . . .
사용자 아바타
내 문제
The screen in the MacBook (Early 2009) had no light. First I changed the inverter and inverter cable but still no light. So I decided to change the LCD panel as well and this did the trick.
나의 수리
I followed the guide to change the LCD panel and had no big problems.
내 조언
Invest in proper tools! Screwdrivers and . . .
사용자 아바타
내 문제
It had begun to crack in a few spots.
나의 수리
The repair went very well. I did not need to remove the screen to install the bezel.
내 조언
Be extra careful with the small clips that help hold the bezel. They are delicate. Pry gently and try to avoid damaging the clips. Use a small flat blade to help install the clip . . .
사용자 아바타
내 문제
MacBook mid-2007 13" screen cracked when lid pushed too far back. Front display bezel showed signs of wear so decided to replace it at same time.
나의 수리
Parts came on time and safely packed. Printed out guide and followed it religiously. Bought very good small screwdriver set at Home Depot for about $1 . . .
사용자 아바타
내 문제
Because it was broken in half
나의 수리
Very well
내 조언
Always buy from iFixIt.com
더 보기
