기기를 수리하세요
수리할 권리
상점
MacBook Unibody (A1342) Trackpad
  • MacBook Unibody (A1342) Trackpad
  • 360°
360
US$74.99
US$74.99
제품 정보
설명
설명
Replace a damaged trackpad and restore the touch sensitivity of your MacBook Unibody (Model A1342) laptop.
A worn out trackpad may have cosmetic scratches or a cracked surface causing it to malfunction. In addition, an aging trackpad may become unresponsive making your laptop difficult to control.
호환성
호환성
  • MacBook 13" Unibody A1342 Late 2009 to Mid 2010
명세서
명세서
Part #:
922-9551, 922-9175, 661-9551
호환성
MacBook Unibody A1342
EMC 2350 2.26 GHz
EMC 2395 2.4 GHz
수리 경험담
사용자 아바타
내 문제
The track pad went from not clicking to moving around sporadically while you tried to click on anything.
나의 수리
It was very simple when following the directions.
내 조언
After installing the track pad dont screw on the bottom immediately. Turn on the computer and check the 'clickage'. You might have to tighten or lo . . .
사용자 아바타
내 문제
I helped my niece purchase her first used computer. When it arrived the trackpad wouldn't click. Instead of sending it back for a refund and realizing we would lose the shipping to and from and then not have a computer, I decided to go ahead and replace it myself.
나의 수리
Part was delivered in a timely manne . . .
사용자 아바타
내 문제
Using ifixit repair guide I bought and installed a new trackpad.
나의 수리
Following the guide It was easy and problem solver in 15 minutes.
내 조언
Ifixit, The right guide at The right place with the right parts!
사용자 아바타
내 문제
Old and dead trackpad.
나의 수리
Only took ten minutes!
내 조언
Works like new! Took me ten minutes to replace the trackpad.
Will order again from iFixit as they use quality parts.
사용자 아바타
내 문제
My white unibody macbook was having problems with the trackpad. After days of searching the internet, trying software fixes, cleaning, checking battery, etc, nothing worked. I finally decided to go for it and buy a new replacement Trackpad with screws, the #00 Phillips Screwdriver, and the Y1 Tri- . . .
사용자 아바타
내 문제
Trackpad clicker didn't work
나의 수리
The instructions were very clear and replacement went easy.
내 조언
After installing the new trackpad the clicker still didn't work. I took it apart and noticed an adjustment screw that actuates the detent. I increased it and then it worked great. I didn't bother to try the old tr . . .
사용자 아바타
내 문제
The battery swelled in the middle so much that it pushed the track pad up our of the computer.
나의 수리
Trackpad replacement seemed at first not to work, new pad was also out of alignment, but shifting the strips that hold it in slightly solved the problem and the track pad aligned. Worked perfectly. Putting . . .
사용자 아바타
내 문제
My trackpad lost it's clicking ability
나의 수리
Replace with a brand new trackpad bought from www.ifixit.com
내 조언
Please don't rush with any of your repairs. That's what I got from my past and present experiences.
사용자 아바타
내 문제
My son dropped his phone onto his trackpad and chipped the corner of it.
나의 수리
We received the part and tool within a couple of days. I reviewed the online repair process and ten minutes later we were up and running again.
내 조언
I would definitely use Ifixit again and recommend the online tutorials. They are ea . . .
사용자 아바타
내 문제
My MacBook track pad was acting up. Unable to click, not very responsive to touch.
나의 수리
The repair process went smooth thanks for the useful detailed guide and all the tools and accessories provided by iFixit.com.
내 조언
If the track pad just not clickable (or having trouble clicking), just need to readjust the . . .
더 보기
